Stick coils for the CBR1000F?
Old Jul 8, 2012 | 09:56 PM
  #131
Hueristic's Avatar
Originally Posted by wooferdog
The Wired George article was written in 2007. I get the impression that this might have been the go-to modification before COP mods became the way to go. Still, it shows merit vis-a-vis more voltage in the LT wiring before the coils.
Should it be considered in conjunction to the Stick coil mod?
Very true.
Originally Posted by Sprock
Interesting for it's time - getting spark a plenty with the "current" upgrade
I suppose you could go for it but me thinks I'll run with these setups for now anyhow.
I guess I'll meter mine when I do it and decide then. I'll let you guys know. I have to finish this first.
OT What I've been up 2 this weekend - Bimmerforums - The Ultimate BMW Forum
Old Jul 8, 2012 | 10:08 PM
  #132
Sprock's Avatar
Look forward to it - we'll be a waiting ........(sound of drummin' fingers) ..lol
awesome engine hoist man
Old Jul 8, 2012 | 10:15 PM
  #133
Hueristic's Avatar
Hahaha thought you'd like it!
Old Jul 8, 2012 | 10:55 PM
  #134
wooferdog's Avatar
Originally Posted by Hueristic
Very true.
Those do not look like Mopar exhaust manifolds or timing cover. It's orange, so I'm guessing a small block Chevy. Is that Glyptol paint in the valley? Nice touch
Old Jul 15, 2012 | 08:16 PM
  #135
wooferdog's Avatar
Finally built my coil harness.
'Bears how-to was easier to follow that oil pan interchangeability
Old Jul 16, 2012 | 06:57 AM
  #136
CBR1988's Avatar
Senior Member & Lord of the Odometer (300,000 Mles) & Counting
Default Scotch brite filters
Right I chopped up a Briggs & Stratton green foam airfilter to do the job
So I guess I 'm powered in part by Briggs & Stratton
Actually the B&S green foam is somewhat oil resistant
Any yeah the old foam winds up in the caps of the slides and then prticles
down the pilot air tubes which could cause rough idling
So pull all the caps off the carbs and go foam fishing while you are at it !
Hey:
I use blue std or green heavy duty Scotch Brite scrubbies for the lawn mowers, all the dirt bikes, race bikes, ATVs, race cars, trucks, tractors and anything else that has a foam filter (r/c aircraft, air compressors). They all go bad (Foam Junk), the scrubbies last way longer, clean up better, pretty cheap to purchase and I can get them everywhere. I used to be a fan of UNI Filters but they even break down over time. I use the spring and shell, then relace the outer with a scrubbie and seal with super glue gel & silicone seal and a ty rap, they never come apart after that. Plenty of years doing this with no issues ever.
(AND I do not own stock in Scotch Brite or the parent company att, but maybe I should come to think of it).
I use the blue for dirt and the green for black top tracks, as the blue could be used for all but is slightly more dense and restrictive, but it filters better.
Dub
Old Jul 16, 2012 | 02:04 PM
  #137
Hueristic's Avatar
Nice, I lost my auction so have to wait for a day and a half for this one. No rush as I'm still assembling the Chevy 350.
Originally Posted by CBR1988
Hey:
I use blue std or green heavy duty Scotch Brite scrubbies for the lawn mowers, all the dirt bikes, race bikes, ATVs, race cars, trucks, tractors and anything else that has a foam filter (r/c aircraft, air compressors). They all go bad (Foam Junk), the scrubbies last longer, clean up better, pretty cheap to purchase and I can get them everywhere. I used to be a fan of UNI Filters but they even break down over time. I use the spring and shell, then relace the outer with a scrubbie and seal with super glue gel & silicone seal and a ty rap, they never come apart after that. Plenty of years doing this with no issues ever.
Dub
Good idea I'll have to remember that!
Old Jul 25, 2012 | 04:33 PM
  #138
Hueristic's Avatar
The more I think about it, the more I like just doing the coil upgrade. It actually removes and improves a couple of aging, potential points of failure. I think doing the relay mod would be adding a potential point of failure without gaining all that much by it
Going back to Hueristic's other question. I saw the RR thread where they say the Gixxer coils will seal themselves. Sebastion (the resident coil guru) has answered the the Suzuki coils have the depth needed for a 1000f. I also think he demonstrated his mod in the how-to using non CBR1000 coils, which I think (and he'll have to confirm) are the shorter type of the coil Honda uses. Suzuki used the same coil on all the GSX-R's regardless of displacement
I live and ride in a rainy locale. I definitely feel the need for proper sealing using one of the methods described here.
Damn I missed this post I ended up buying cbr sticks. AFA the relay mod I agree I'm not going to add another possible point of failure, I'll do the coils then the relay. Also My Dad made a good point that I didn't have the answer too.
He asked "If you put a relay in the circuit will the delay in the relay affect the timing? I have no clue as to a standard relays delay and if it is significant enough to affect timing?
Originally Posted by Sebastionbear
Stick coil How To for the CBR1000F posted.......
https://cbrforum.com/forum/how-tos-8...0/#post1173483
PM me with an email addy that I can send the PDF to, if you wish.
Cheers, SB
Following now. Never did find my heat shrink but I found some wiring braid that I used for Power supply's so that should d the trick.
Old Jul 25, 2012 | 05:01 PM
  #139
Sebastionbear1's Avatar
Ok a bit of clarification here guys........
In the mod for the CBR1000F, I used Honda CBR929 coils sourced by Sprock. I have used Suzuki stick coils before for the Kawasaki GTR1000 stick coil mod.
The CBR929 and Suzuki GSX-R600/750 Denso coils that I have here are the same length. Neither will seal on the wide spark plug well the CBR1000F has, which is why the simplest, most expedient method of providing waterproofing was cutting off the original rubber sealing covers from the OEM coil.
And I do think perhaps the Stick Coil Guru (behind the scenes) is Naga-Thai
Cheers, SB
Old Jul 25, 2012 | 07:39 PM
  #140
Hueristic's Avatar
Cheers, SB
Guess what? I forgot to test fit mine first! LOL I got CBR1000rr sticks IIRC.
Yup
http://www.ebay.com/itm/230824118722...84.m1497.l2649
