Stick coils for the CBR1000F?
Old Jul 29, 2012 | 08:54 AM
  #161
Hueristic's Avatar
Thanks guys but I know what I'm talking about. I do have a EE degree. There is a delay in any mechanical device, relays have a mechanical switch powered by a coil. I appreciate you guys trying to explain but I'm talking about a very miniscule amount of time but one that will retard the spark because of it's inherent design.
Here:
This should explain my question better.
Old Sep 17, 2012 | 08:57 AM
  #162
coolerthanelvis's Avatar
The relay mod is done to eliminate any voltage drops in the switched power circuit feeding constant 12VDC to the ignition circuit. I haven't seen a diagram for the Katana system that was referenced earlier, but in this diagram: Name:  wiring.jpg
it looks like the black/white wire is the switched 12VDC. The coils are being supplied with constant power and the Pulse Generator Coils tell the Spark Unit which coil to connect to ground (green wire) at what time, thus causing the electrical field in the coil to collapse, thereby generating the huge voltage needed by the spark plugs. The relay would be on whenever the key was on so you wouldn't have to worry about the 3msec delay because it would only happen once, just as the key is switched on.
Your diagram shows a load supplied with intermittent power; whenever the horn button is pressed, there is a delay as the coil energizes and activates the switch in the relay, then the horn sounds. In our application the relay would be getting steady power and the "switching" happens downstream of the coils, so no delay after the initial triggering of the relay.
Old Sep 18, 2012 | 04:29 PM
  #163
Hueristic's Avatar
Originally Posted by coolerthanelvis
The relay mod is done to eliminate any voltage drops in the switched power circuit feeding constant 12VDC to the ignition circuit. I haven't seen a diagram for the Katana system that was referenced earlier, but in this diagram: {snip}
What? It has no bearing on whether the relay has un switched potential already. The delay is when the power to the relay's coil is activated by the Pulse Generator thereby activating the coil which in turn closes the switch. There is no way on gods green earth you can do this with no delay. Unless you know how to ignore the laws of physics.
Old Sep 18, 2012 | 05:20 PM
  #164
bohdan's Avatar
The relay would be on whenever the key was on so you wouldn't have to worry about the 3msec delay because it would only happen *once*, just as the key is switched on.
EXACTLY! +1. Pure and simple.
I also tried to point this out already earlier. The relay is NOT being switched in time with the pulse generator, it is only switching once at power on to supply +12 towards the coils. Completely agree.
Cheers
Kevin.
Old Sep 18, 2012 | 05:37 PM
  #165
bohdan's Avatar
This is what it actually looks like. The relay ONLY switches at the time power is applied by the ignition switch.
Old Sep 18, 2012 | 06:09 PM
  #166
Hueristic's Avatar
Old Sep 19, 2012 | 07:03 AM
  #167
kiwi TK's Avatar
Crazy CBR Salvage Guy. RIP
Is it any wonder us mere mortals get scared by the dark side stuff?
And Hi Bohdan, you've been quiet lately, bike reged for the summer?
Old Sep 19, 2012 | 05:19 PM
  #168
bohdan's Avatar
Hello K-TK, Yes almost - have been in the US for the last 5 weeks so am home now and completing some maintenance issues at the moment. Have just changed the CCT and done valve clearances (surprisingly EX were all good but the INs were tight as the proverbials proverbial). Also have done the coil stick mod. Still have to replace the vacuum line to the petcock, synch the carbs, fluids and filters and hopefully should be good to go before October.
I only got to do a few hundred Kms on the bike when I bought it before suspending the reg over winter, so am looking forward to giving it a good run.
Is everything good for you?
Cheers
Kevin
Old Sep 20, 2012 | 12:57 AM
  #169
bohdan's Avatar
Here's your problem. The power to the relay coil is not activated by the pulse generator. If you take a moment of your time to look at the schematic I sketched yesterday, you will see precisely that.
Old Sep 20, 2012 | 11:27 AM
  #170
Hueristic's Avatar
Ahh, Now I understand why we are not getting our points across to each other. Apparently the schematic I initially read was completing the circuit with the spark generator to ground closing the relay where as this circuit (which you are correct I did not look at: being a thick headed Irishman ) will indeed bypass the spark generator.
I believe The initial relay Mod I had found was more than likely a early mod that was improved with this one. Thanks for finally getting that into my thick skull.
BTW on your drawing for others that may read this and not know, Draw a box around the coil and switch and label for ease of reading. Unless you know how to read schematics those 2 have no reference to each other than K1 which really is not intuitive.
Well if nothing else I'm really glad you guys didn't give up on me because If I had done the original Mod and started having problems there is no way anyone could have figured out the issue!
I was also unaware that the pulse generators were nothing more than a completion to ground with a spark unit in between. I assumed it closed the circuit for the 12v to the coil, which I believe was the tap in the initial circuit I read. After going back to this diagram it makes perfect sense now.
Now I understand what CoolerThanElvis meant when he said " I haven't seen a diagram for the Katana system that was referenced earlier".
My apologies to all you guys. I can admit when I am wrong. Although we were talking about 2 different circuits. I was dumbfounded that you guys didn't get what I was saying so much that I missed the forest for the trees!
