Stick coils for the CBR1000F?
Old Dec 9, 2012 | 01:34 PM
  #191
ranchome's Avatar
I got them done and installed today. The air temp wasn't cold but unless it's my imagination (placebo effect) it did seem to start better. I didn't get to warm it up completely because it started pouring rain and I don't have a garage.
So weather permitting, supposed to be cold all week, I may get to try out the cold start benifit.
Old Dec 9, 2012 | 02:49 PM
  #192
TimBucTwo's Avatar
^Nice job and I firmly believe they do start better. The idle is a no brainer, they idle much smoother.
Old Dec 9, 2012 | 04:05 PM
  #193
ranchome's Avatar
Thanks TBT I think it turned out well
Old Dec 9, 2012 | 08:02 PM
  #194
tobiahr's Avatar
ranchome, what did you wind up using for the seals? those look good whatever they are.
Old Dec 12, 2012 | 07:58 AM
  #195
ranchome's Avatar
I used the 'tip toe' washers Sprock recommended from Ace Hardware. They're a perfect fit. I sealed them on with some black silicone.
I may still cut the original ones off my stock coils because the washers don't seal complete.
I have to drive a little way in gravel and I get little pebbles on top of the head cover.
I'd hate for one if those to fall down I'm my plug hole!!
Old Dec 12, 2012 | 10:15 AM
  #196
TimBucTwo's Avatar
The way I did mine works great to keep debris out of the wells but not the most sophisticated by any means. Perhaps some silicone between the parts would work even better but I saw no need at the time. They hold the sticks dead solid in the center of the wells. I don't get any movement of the sticks and that's why I don't plan on changing them.
Sprock also had a part# for a Ford PCV seal but I don't remember a photo showing them installed.
reference to page #5
Old Dec 14, 2012 | 09:44 AM
  #197
Sprock's Avatar
Well then I guess I was remiss - well if it warms up sometime soon I'll head out and snap
a pic of the Ford PCV rubbers on the 93 and get the part number I know I bought more
than one set - std operating procedure
Nice job with the stick coils there Steve - it's a great upgrade
Old Dec 15, 2012 | 06:43 AM
  #198
ranchome's Avatar
Thanks Sprock ol buddy
Old Mar 19, 2013 | 11:46 AM
  #199
thedrewski86's Avatar
Welcome Crew
I'm looking into this mod now, from what I've read the newest cbr1000 coils I can get are best and I need a loom. I assume the loom is like this piece?
04-05 Coil Wire Harness
There is no particular year for the loom? I could do an '04 loom w/ '08 coils for example?
Old Mar 19, 2013 | 02:48 PM
  #200
Sebastionbear1's Avatar
As long as the plugs on the loom suit the coils all is good. I cut my loom up and ONLY used the plugs anyway.
Good luck with the mod.
Cheers, SB
