No spark= Unhappy
Old Aug 10, 2013 | 05:19 PM
  #51
msebastianCBR's Avatar
ROTM, Nov 2014
Originally Posted by 74demon
The ecm is not a common failure part, but shouldnt be overlooked. It would be nice if you could borrow a known good one to test.
How far down was the motor? Could one of the pickups be damaged or something? I've heard of stuff like that happening.
The cylinder head was off, I put everything back together according to the manual. That would be nice. Is the 929 ECM the same as the 954.
Old Aug 10, 2013 | 05:34 PM
  #52
74demon's Avatar
Nope. Not even close.
Old Aug 11, 2013 | 04:05 PM
  #53
ROTM, Nov 2014
So I guess the next step is 2 get the bottom part of the ignition switch, IPG sensor, and a new battery. That will rule out several critical parts to the ignition system. There is also a resistor that I am also going to get as well that is by the 3 relays.
Old Aug 11, 2013 | 04:18 PM
  #54
74demon's Avatar
Are you talking about the clutch diode?
Is this bike a US bike originally?
Old Aug 11, 2013 | 04:51 PM
  #55
ROTM, Nov 2014
Honda Motorcycle Parts 2002 CBR900RR A WIRE HARNESS (2) Diagram
Part number 12 on the above address. Yes it is a US spec 954.
Old Aug 11, 2013 | 08:40 PM
  #56
ROTM, Nov 2014
Would a jacked up frayed and falling apart neutral switch cause all of this. The neutral switch was frayed and basically fell apart when I took it off. The green plug that goes to the shifter is what I am talking about. The plug that plugs into the shifter is what was damaged.
Old Aug 11, 2013 | 08:55 PM
  #57
74demon's Avatar
I think that a bad neutral switch circuit would cause a "no crank" condition.
Needs to be fixed anyway, so it's worth a try.
Old Aug 12, 2013 | 07:15 PM
  #58
ROTM, Nov 2014
It was actually the stand switch. I fixed it and still nothing. Would a no spark have anything to do with how the head and cams were reinstalled. I followed the manual and I am pretty sure I put it back together properly. It is really just something that I have been thinking about.
Old Aug 13, 2013 | 05:53 PM
  #59
ROTM, Nov 2014
Any suggestions or thoughts on this. ^^^^
Old Aug 13, 2013 | 06:11 PM
  #60
74demon's Avatar
You should still have spark, unless the exciters for the cam or crank sensors are messed up or missing.
Other than that.....?????
