No spark= Unhappy
#101
Well I decided that there is no use in building the engine only to find out my problems are an electrical issue. So I am going to get a new head gasket, manual tensioner, pair block off plates, and a few other bits and see if this thing will run with the timing set properly. The engine is out so I can easily access the entire engine and set the timing and put it all back together properly. Hopefully once put back together this thing will run and I can go on with the rebuild. If not I will know it is not the engine and track down whatever else could be wrong. I am under the impression that a bad tensioner can cause the tick that the previous owner described. So that is why I am getting the manual tensioner. The engine turns over just fine and is smooth and does not stick so I do not believe I have a bottom end issue. So wish me luck and I hope all goes right the third time. Oh yeah I am going to go with OEM oversized pistons and rings when I do the 76mm rebuild instead of the wiseco kit I was initially going to go with.
#102
The oem oversize pistons are 75.25mm and have same compression ratio as the oem 75mm pistons. If the piston skirts and cylinder walls are scratched like they normally are in the 954 the cheapest option would probably to check some reputable shop whit good equipment can they recondition the oem pistons and get the the stock bore welded if it needs it and then plated. That way only new parts needed would be the ones that are out of spec+ new seals, gaskets, bolts, probably new piston rings etc. I wouldn't see any real benefits on the oem 75.25 pistons.
#103
http://www.usnicom.com/plating/pistonCoatings
#104
#105
I looked at their price sheet and it still looks like it will be around $850 for the welding, plating, honing, and piston coating. But like I said I am going to give them a call tomorrow and see if they can give me an estimate without actually seeing the case and pistons. That still saves me close to $400 and not having to buy new pistons. Plus they say the coatings on the pistons make the engine last longer and wear better and should do away with the scarring in the future. I also think they said it does improve performance as well so that seems like a winner to me.
#106
#107
I actually got my piston skirts coated whit tech lines coating. It feels very slick compared to the machined surface that they came whit from Wiseco. In my opinnion the coating should reduce friction, heat and whit it you can run tighter piston to cylinder wall clearence whits equals more power. Even if you use oem piston whit the piston skirt coating and the nicasil plating in the cylinder walls you can run much tighter clearence so it should make little more power then stock. Add to that a good port and valve seat job on the head and good exhaust and you should be making about 155-160 rwhp. The crank i would allso get polished and rebalanced. I don't know how much the 954RR counterweights have weight difference but GSX-R 1000 counterweights have been balanced to 5 grams of each other. Machine shop whit normal equipment to balance the crank can normally balance them to 1 gram or whit very good equipment even less.
#108
I just got off the phone with them and I am really happy with the info and the price. He said there is probably not a need to do any welding or honing to the cylinders since I am still in spec for the piston to wall clearance. So he said I will need to have it re plated and do the piston skirt coating. If that is all I need then I am also going to go with the thermal coating on the piston dome as well. If I do have to have welding or honing that will be another $200 and I may decide against the thermal coating. So my estimate was high and they can possibly do the work for $609, $709 with the thermal coating. And if the block needs welding or honing then it would be an additional $200 to those prices. That saves me anywhere from $600 -$400 dollars. Thank you Mika for the info and saving me money, I definitely appreciate it.
Are you trying to get any more power out of it? What are the other mods?
You're welcome for the info!
#109
I think that the thermal coating isn't very usefull on a bike whit that compression. It just keeps the bike little cooler but the 954RR doesn't have any overheating issues even little modified so i would put that money on something ellse. For me it could have been usefull because i'm running 13.5:1 compression ratio. The thermal coating just would have been a lot pricier here in Finland. Little under 200€ if i remember correct.
I am not really going for power since this will be my first liter bike. I am going more for a reliable bike that I don't have to work on constantly. Most of the mods I will be doing is for looks and not necessarily power. I currently have a k&n air filter, pair mod, and a d&d slip-on with 8 inches cut off the back. I am going to make an under belly exhaust for the bike which will make the bike slightly louder but will do away with the big hunk of metal on the side. My 03 600rr spoiled me and I like the exhaust to be out of the way.
I might put the money your advice is going to save me towards new fairings and a tank respray to match the new fairings. The previous owner got cheapo Chinese fairings and they look like poop and are flimsy as hell. Plus the tabs are glued on and most of them have broken off. I am also having the frame, sub frame, swing arm, case covers, upper and lower triple tree, rear sets, and passenger pegs and bracket powder coated. I am still debating on if I should go flat black or gloss black. By the way I am either going white repsol, white moto gp (like t4rusaf), or either oem titanium or titanium moto gp fairings.
#110
I researched the thermal coating after the last post and what you said is correct, it is mostly used for race engines or diesel engines that get really hot. I will be using the engine ice coolant and that will lower temps by up to 50 degrees. It worked real well on my 09 ninja 250 and 03 600rr when I had those bikes.
