digital cable and computer nerd question
Old Nov 17, 2006 | 01:16 PM
rrasco's Avatar
Default RE: digital cable and computer nerd question
You may be getting a drive letter conflict that occasionally occurs when using USB flash drives or pens. I am not sure if this is how the DVR works, but it is worth a look. I know some high end DVRs have Cat-5 connections that is a shared network drive you can drag and drop from.
Do this:
Right Click on 'My Computer' and select 'Manage...'
This will open up the Computer Management Console
On the left, select 'Disk Management', this brings up all of your current disk drives as well as their relative information, including drive letter. On the lower right look for a removable drive. Such as this pen drive.
Check to see if there is a letter assigned at all, or if it is assigned the same letter as another drive. This normally happens on mapped network drives that dont know something else is trying to use that assigned letter, thus not letting you see it. If there is a conflict change it like this:
Right click on the Disk #(the removable one), and select 'Change Drive Letter and Paths':
Click 'Change':
Now select a different drive letter that is not in use and click 'OK'.
You can now close the Computer management console and the drive should be accessible from My computer, that is if these DVRs even work this way.
Hope this helps.
Old Nov 17, 2006 | 02:14 PM
VP's Avatar
VP
^^^^ ???? Damn you RRasco and your boring *** job. You get the time to learn the stuff we all need to know. At least you're putting it to good use.
Old Nov 17, 2006 | 07:17 PM
TennesseeCBRF2's Avatar
I don't have Media Center, and my cable company is Comcast.
Old Nov 17, 2006 | 10:28 PM
psycojester's Avatar
yea the outputs on the back of the dcts like cat 5 and usb are thier just for looks. You will need to run it though a dvd burner then. only way possable
Old Nov 18, 2006 | 02:28 AM
rrasco's Avatar
ORIGINAL: psycojester
i could believe they were there for an insignificant under functioned reason, but i am sure they put them on there for more than just looks.
Old Nov 18, 2006 | 02:42 AM
nope just for looks. they are their to put info onto the dct not to take them off.
Old Nov 18, 2006 | 12:50 PM
Damn that sucks! Now should I erase Pink Floyd's "The Wall" or Red Hot Chili Peppers live in HD?
jdschmidt
Feb 5, 2010 02:39 PM
txsmainevent
Oct 29, 2008 08:26 PM
D2VW14_20
Apr 13, 2008 08:48 PM
redzintimidator
Jan 14, 2008 06:51 PM
ampfp
Oct 3, 2006 01:53 AM
