started button sticking
Old Oct 2, 2007 | 07:36 PM
USMCVET's Avatar
Default started button sticking
The starter button on my '01 929 has started to stick as of 10 minutes ago. I got on it to run to the store and no headlights. I took the cage, and when i got back and tried to start the bike and as soon as I turned the key it fired up. My question is can I spray some silicone lube in there to help it, or does it need to be replaced. Thanks
Old Oct 2, 2007 | 07:59 PM
pacemaker's Avatar
Default RE: started button sticking
Undo the top of the switch block with the retaining screw(s). Turn it over to get better access, I tend to use electrical switch lube & cleaner on stuff like this, but if you have to, WD can be used in a pinch. It just sounds like the switch has got gummed up from crud, so I think it will be sweet & you will not have to replace it.
Old Oct 2, 2007 | 08:20 PM
knightslugger's Avatar
yeap. just get some electrical contact cleaner, blast it, then use a di-electric grease on the contact (white lith grease will work well too) and close it back up.
good as fixed.
sawnee
Dec 20, 2008 04:44 PM
KLO
North East
Oct 29, 2008 03:01 PM
ludespeedny
Apr 13, 2008 12:11 PM
MikeZ
Apr 1, 2008 03:17 PM
skarocka
Mar 10, 2008 08:51 PM
