sticking throttle
Old Apr 11, 2008 | 06:54 PM
ludespeedny's Avatar
Default sticking throttle
I have noticed that my throttle doesn't return on it's own. I know the grips have been replaced, and that's what the person I bought the bike thought it would be. What should I try to do to fix this?
Old Apr 11, 2008 | 07:22 PM
Asmittie84's Avatar
Default RE: sticking throttle
Adjust those two adjusters next to the throttle. There should be 2. Mine use to stick like that too and I adjusted them some and it snaps back perfect.
Worste case scenerio someone got Grip Glue in them and it just needs to be cleaned out. But I'm guessing they are adjusted wrong. Just screw around with them until it feels good.
Old Apr 12, 2008 | 03:48 AM
rider0033's Avatar
you can also make sure that your carbs are clean. old varnished gas will make the throttle plates return slowly also.
Old Apr 12, 2008 | 05:19 AM
pacemaker's Avatar
Check to see that the end bar weight isn't done up so tight to be pushing up against the new grip
Old Apr 12, 2008 | 10:15 AM
marc0011's Avatar
I've had problems where the grip and bar weight rub up against each other and the throttle closes slowly. One thing about adjusting the throttle at the bar, it is limited. The main adjustment is at the carbs. If you pull off your airbox and follow the cables, you'll see what I am talking about. There is an adjustment that is similar to theadjustmentat the end of the clutch cable.
Old Apr 12, 2008 | 12:20 PM
cannon's Avatar
i had a throttle problem myself, it ended up being a bent clip on. so check your handlebar, if your bike was ever dropped it could have a bend to it that would stick to the throttle which would still be straight. good luck
Old Apr 12, 2008 | 12:32 PM
bullit_70's Avatar
ORIGINAL: cannon
i just had this happen to me and i got pulled over for it. the guy that i bought my bike from droped it in his drive way. i have a bent handle bar and a cracked thottle sleve. but i will have it back from the shop monday or tuesday :-) just my .02
Old Apr 13, 2008 | 11:35 AM
I took off the bar end, and loosened up the screws at the base of the handlebars, and it moves freely, and can even hear the carbs snap. It appears to be the grip rubbing on either end. I am going out today to trim them up some.
Is there a way to lubricate the throttle cables?
Old Apr 13, 2008 | 12:11 PM
KidCr3nshaw's Avatar
There is some stuff specifically, I think, for lubing throttle cables. I used graphite. Super cheap and works forever.
Jonnywright
Jun 3, 2012 07:06 AM
sawnee
Dec 20, 2008 04:44 PM
KLO
North East
Oct 29, 2008 03:01 PM
KLO
Oct 27, 2008 07:40 PM
SPoolinspOON
Jun 16, 2006 09:46 AM
