Throttle sticking
Old May 18, 2006 | 11:09 AM
SPoolinspOON's Avatar
Default Throttle sticking
I just bought a 94 F2 and when the bike is off I pull the throttle, it doesnt spring back it its original position. Why is that? My friend has teh same problem, but my other friend's throttle goes back.
Old May 18, 2006 | 12:14 PM
furiousf2's Avatar
Default RE: Throttle sticking
I had the same prob once also. Try taking off or loosening the barend. Maybe even spray some WD40 in there. Mine would work fine during idle and not when turned off. I'm sure that you know but it won't pass inspection if it sticks at all.
Old Jun 5, 2006 | 02:17 PM
doublechester15's Avatar
The throttle cable may need adjustment. It is simple. I am quite sure that you can access it through the left fairing service panel. THe cable has a lower and an upper. The lower controls the spring back, the upper controls the response. When the upper is adjusted more tightly than the lower it will not spring back properly. You must adjust the cables using the lock nuts and make sure that you set the lower tighter than the upper. Then adjust the upper to how you like your throttle response. Make sense, you'll see when you get there.
Old Jun 11, 2006 | 03:34 AM
plastikmelter's Avatar
i spent 3 hours working on my throttle today because it wouldnt spring back it all. what i learned is that your cables need to be strecthed out and not coiled. i had the carbs off and when i hooked up the cables and pulled them so they were straightened out and not under any tension the throttle popped back like it was suppose to. also, its worth taking your grip off just to see things better. mine was rubbing against the kill switch area and was causing the throttle to stick as well. hopefully this will help someone cause it shouldnt be complicated if you know what to look for, needless to say i didnt....haha
Old Jun 16, 2006 | 09:46 AM
wayne_carey's Avatar
i found with my 93 600f that the 90 degree bend on the cable located at the throttle handle just needed to be moved side to side until i found a position that it would return in. just loosen it with a spanner and change its position until you find it returning. hope that helps ya
Jonnywright
Jun 3, 2012 07:06 AM
(951) Baby Shortee
Apr 2, 2009 05:24 PM
sawnee
Dec 20, 2008 04:44 PM
KLO
North East
Oct 29, 2008 03:01 PM
KLO
Oct 27, 2008 07:40 PM
