Sticking Throttle
Old Mar 27, 2008 | 09:12 PM
MikeZ's Avatar
From: Granger, Indiana (Next to South Bend and Notre Dame)
Default Sticking Throttle
I just got done putting in the Dynojet Kit and now my throttle likes to stick, then not stick, then sticks, etc. I just want to know if you guys have any ideas of what it could be, we messed with it for a while but it just keeps sticking.
Old Mar 27, 2008 | 10:48 PM
FNQuickF2's Avatar
Default RE: Sticking Throttle
Hmmm....double check your cable. Next could be the springs, collars, diaphragm assemblies...
How I hate carburation probs!
Good Luck!
Ron
Old Mar 28, 2008 | 11:10 AM
crx2cbr's Avatar
i had the same problem with my bike after awhile, it was my throttle sticking to my bars, the plastic sleeve that slides onto the handlebar, i took the sleeve with the grip off my bar, sprayed some carb cleaner in the plastic sleeve and then pulled a rag thru the sleeve a few times, and repeated it a few times with the carb cleaner, then took a peice of 4 or 500grit sand paper and sanded my bar and cleaned and crap off of it and put it all back together and it works great now, but dont put and grease or oil on the bar and slide the sleeve back on, it will make it stick again, and you dont want what
Old Mar 31, 2008 | 07:34 PM
irocthestreet's Avatar
wow reading owns you michael. there is this neat feature in pretty much all forums called a search button. But i forgot that your cbr is different from all other 93 cbrs. I think i know what the problem is. you vtech is not kicking in until around 7krpm range causing the engine oil to not heat up fast enough. with the engine oil opperating at a lower temperature that causes the gas filled shocks to not losen up.i think the solution to this is to take off your exhaust bearing and check for it being spun.if it is youll need to install some new blinker fluid. yours seem very dim anyway. OR IT COULD BE THAT YOU ARE SLOWWWWWWWWW. you should of just bought a bmx bike. i got a huffy ill trade you for that honda. then maybe you can get laid. i swear to god .
alright that was all a joke, but seriously wanna trade?
ill even let you drive my s10. you owe me for the gas i spent taking you to see those girls anyway so we will call it a fair trade
Old Apr 1, 2008 | 06:29 AM
fjbiel's Avatar
I am pretty sure that was uncalled for.
Old Apr 1, 2008 | 07:33 AM
JeepontheRocks's Avatar
That rant didn't even make sense.. I think he owned himself..
Old Apr 1, 2008 | 03:17 PM
Im friends with michael and was just giving him a hard time, calm down
Jonnywright
Jun 3, 2012 07:06 AM
sawnee
Dec 20, 2008 04:44 PM
KLO
North East
Oct 29, 2008 03:01 PM
KLO
Oct 27, 2008 07:40 PM
SPoolinspOON
Jun 16, 2006 09:46 AM
