miles? weird noise!
Old Sep 25, 2005 | 04:38 AM
pextis's Avatar
Default miles? weird noise!
I test drived a 2001 600 F4i and was quite impressed,,but it has 24k miles,,is that so bad? Also while it was in nutral and i reved it, as soon as it reached around 4000 rpm it made a weird rattling noise near the right side(very distinct,,not loud at all),,,and i was told that it was a certain spring thats meant to hold the timing chain tight, and went loose, and that its a common problem of this model! Is that true? I'll appreciate any feedback since i really am interested in buying it! Thanks.
Old Sep 25, 2005 | 12:31 PM
blinkster240's Avatar
Default RE: miles? weird noise!
cam chain tensioner is a very common problem with the cbr 600 f4i. i replaced mine one thousand miles ago, i only have 16000 on my bike. its a great bike so if you are getting it from a dealer get them to fix it before you buy it because it was a pain to replace due to the location of the c.c.t. i also hear a manual tensioner is the way to go.
[IMG]local://upfiles/2647/B5D1A96C3B5643DFB2E6A96A864C3CEE.jpg[/IMG]
Old Sep 25, 2005 | 11:34 PM
SquireSCA's Avatar
Do the '05's suffer from this, or have they fixed the problem?
Old Sep 26, 2005 | 02:01 AM
pextis's Avatar
so will the cam chain tensioner problem decrease the bikes performance? Thanks!
Old Sep 26, 2005 | 02:02 PM
not sure if it will decrease the power because i changed mine within a week of that annoying rattle....
Old Sep 26, 2005 | 03:20 PM
p166mmx73's Avatar
I believe you should only hear the cam chain tensioner problem when the bike is in gear or under load. So, if you are hearing something when in neutral it might be something else.
hikeetech
Jul 20, 2011 11:16 PM
pimpax56
Dec 2, 2009 12:14 AM
sdpbob
Jul 4, 2009 07:20 PM
3wheelerlouie
Apr 15, 2009 09:14 AM
1badeg
Jul 16, 2008 10:50 AM
