Weird noise
Old Jul 8, 2008 | 03:09 PM
1badeg's Avatar
Default Weird noise
What's going on everyone. I have a 99 blade and have something weird happening about once every other day or so. I'll come up to a light or to a stop and I'll hear like what sounds to me like a pressure release type sound....you know, how a semi truck releases line pressure? It's coming from under the tank but I haven't been able to pinpoint it or figure out what it is or what's causing it. Hopefully someone can help me out, cause it's driving me nuts....thanks everyone for your time.
Old Jul 8, 2008 | 09:20 PM
900FighterRR's Avatar
Default RE: Weird noise
any chance one of your carb slides is sticking and causing a slight backfire into the air box? Sounds crazy but I've seen it. YOu might be able to tell if you see any singing of the filter element or air box. Thats a long shot though. is this an actual hiss of air? If you had a vac leak it would be all the time not intermitten. Could also be a clogged vent tube? I would love to hear this sound. Try adescribe it a bit more because I can't imagine a bike making an air brakes pressure blow off sound. Good luck
Old Jul 9, 2008 | 05:10 PM
stynkmonkey's Avatar
Unless I'm mistaken nothing under there should have stored pressure like that. Here's a long shot but could it be coming from your rear shock? you might have a leak in the hose to the reservoir. It's not exactly under the tank but in that general area and could explain why you hear it on stopping as the rear shock settles.
Old Jul 10, 2008 | 09:06 AM
Jeff1980's Avatar
My guess would be the radiator overflow hose or possibly fuel overflowdripping just once onto the hot exhaust and what you're hearing is theliquid sizzling. Check under your bike and see if any of your drain hoses are aiming at, or near your exhaust.
Old Jul 16, 2008 | 10:50 AM
1badeg's Avatar
Well guys, noise hasn't happened since then.....but I'll definitely keep you guys informed once it happens again and once I'm able to duplicate and track the noise down....thanks for all your help.
Projectrockstar
Apr 26, 2012 04:02 AM
hikeetech
Jul 20, 2011 11:16 PM
pimpax56
Dec 2, 2009 12:14 AM
sdpbob
Jul 4, 2009 07:20 PM
3wheelerlouie
Apr 15, 2009 09:14 AM
