Right turn signal problem!!
Old 09-20-2006, 12:12 PM
fafar59's Avatar
Default Right turn signal problem!!
Hi experts!!
My right turn signal works when I hit the switch, but it is switched off normally instate of being lit all the time. I have checked all the connections. They are all properly connected. Can you help me with this issue?
Farokh
Old 09-20-2006, 03:46 PM
bobjoezx's Avatar
Default RE: Right turn signal problem!!
are you staying the light doesn't stay on when you let off the switch, maybe i am reading it wrong but i dont exactly understand your problem
Old 09-20-2006, 05:40 PM
VP's Avatar
VP
VP is offline
I think he's saying his lights are running lights and the bulb works when he uses the turn signal but it's turned off when he's not using the blinker
Old 09-20-2006, 07:16 PM
bobjoezx's Avatar
are they stock or aftermarket.. because aftermarket is usually 2 wire, stock is 3 so u got to figure out if u want running lights or blinkers, but i dont thnk that's what u mean
Old 09-21-2006, 08:28 PM
fafar59's Avatar
My turn signals are stock with three wire. Sorry for being confusing, Yes i mean it turns of when i let the blink go instant or running.
Old 09-21-2006, 09:02 PM
bobjoezx's Avatar
taht might be something in the switch but i am not exactly sure i would kinda have to be there and check it out... but i am thkning switch
Old 09-21-2006, 10:03 PM
VP's Avatar
VP
VP is offline
relevent question: how do you take off the blinkers on both sides? does it require removal of the entire front fairing?
Old 09-22-2006, 01:25 AM
bobjoezx's Avatar
eh depends usually just take some of it apart and see if u can get to the wires, got to buy the right size, and make sure u wire them up right
Fallen3
09-28-2010 03:56 PM
RoosterF3
F2 Tech
14
04-10-2010 09:26 AM
utter05
01-22-2009 01:10 PM
Stugots
05-01-2008 03:51 AM
dewthedoo05
09-04-2007 09:32 PM
Quick Reply: Right turn signal problem!!
