Turn signal problem
Old Jan 22, 2009 | 07:25 AM
utter05's Avatar
March 2009 ROTM
Default Turn signal problem
I recently bought and installed an LEDintegrated taillight
since led dont draw as much power my signal now blinks
1000 times a minute, the guy i bought it from said i have
to use his special solid state relay which is 25 bucks to
correct the blink speed. Is this trus or can i get a relay
from radio shack that will function the same?
He also saida different route i could go is to put
resistors into all the wires but i do not want to cut
up all the wires and splice in resistors.
Old Jan 22, 2009 | 11:52 AM
redzintimidator's Avatar
Default RE: Turn signal problem
i got a variable load flasher relay on ebay for $5...works flawlessly. highly recommend this versus the resistor method cause they heat up VERY hot
Old Jan 22, 2009 | 11:53 AM
ps - make sure the flasher relay is 2 wire
Old Jan 22, 2009 | 12:00 PM
utter05's Avatar
March 2009 ROTM
I'll check it out on ebay
I need a 2 wire relay and how do i know
i am getting the right part that i need.
Old Jan 22, 2009 | 01:01 PM
willduce's Avatar
if you got a clear alternatives light...it should have come with the 2 resistors,
Old Jan 22, 2009 | 01:10 PM
utter05's Avatar
March 2009 ROTM
it is not a clear alternatives light
Fallen3
Sep 28, 2010 03:56 PM
RoosterF3
F2 Tech
14
Apr 10, 2010 09:26 AM
Stugots
May 1, 2008 03:51 AM
dewthedoo05
Sep 4, 2007 09:32 PM
gotcharr
Mar 3, 2006 11:48 PM
