TURN SIGNAL PROBLEM
Old Apr 29, 2008 | 12:24 PM
Stugots's Avatar
Default TURN SIGNAL PROBLEM
I have a 01' 929....the rear left blinker works, but the continous background light does not. I have changed bulbs...same problem. Also, on the instrument panel the right turn signal indicator stays lit? So it looks like a left / right issue going on. Any help would be greatly appreciated.
Old Apr 29, 2008 | 04:47 PM
pixel 6's Avatar
Default RE: TURN SIGNAL PROBLEM
Similar thing happened to me. Do you have some sort of aftermarket resistor / relay box wired to your rear blinkers to make them flash slower?
Mine did, and that failed. As soon as I took that component out, it wired up fine.
Mine was funky tho to lol... if I hit the front brake lever... my left blinker would lock on =P
- Pixel -
Old Apr 30, 2008 | 10:43 AM
Stugots's Avatar
Nothing funky wired...kind of have it narrowed down. The running lights should only be on the main fairing....the two rear turn signal lights should not stay lit, but my right rear does? I completely disconnected the rear right signal...plugged it in the left side...worked perfectly....so my problem is from the right clip forward....GREAT!
Old Apr 30, 2008 | 09:32 PM
Stugots's Avatar
Well...found out what was wrong. The front right bulb was jammed and a little rusty...cleaned and replaced...good as new!! Thanks for all of the powerful insight.
Old May 1, 2008 | 03:51 AM
pixel 6's Avatar
Pfft. Easy one!
Mine involved multi-meters, wiring diagrams, wire cutters, solder, shrink tubing... etc.
- Pixel -
Fallen3
Sep 28, 2010 03:56 PM
RoosterF3
F2 Tech
14
Apr 10, 2010 09:26 AM
utter05
Jan 22, 2009 01:10 PM
dewthedoo05
Sep 4, 2007 09:32 PM
gotcharr
Mar 3, 2006 11:48 PM
