Turn signal problem
Old Sep 27, 2010 | 03:25 PM
Fallen3's Avatar
Default Turn signal problem
So I finally managed to fix my bike after my accident in December, and my turn signals came in the mail yesterday. I bought some flushmounts from Hot Bodies, and I spent my morning installing. Before finishing everything up, I checked to make sure that they worked. Everything was fine before I tightened everything up.
I just took my first ride since December, and I notice that my turn signals don't turn on at all. It doesn't even show in the dash. Any help? I'm thinking that I pinched a wire somewhere.. but I can't imagine where.
Oh, and it's a 2005 F4i.
Ninja Edit:
I just found out my brake lights don't work either... scary. Help, please?
Old Sep 27, 2010 | 05:49 PM
gotcbr's Avatar
Maybe a blown fuse.
Old Sep 27, 2010 | 06:08 PM
Fallen3's Avatar
I was thinking that too... but I'd rather make sure that I don't replace the fuse and have it blow out again.
Thanks though.
Old Sep 27, 2010 | 07:25 PM
gotcbr's Avatar
So...do you or don't you have a blown fuse?
You need to know if you've got a fuse that's blown. Pop another one in there & see if it pops too. If it does, you've got a wiring problem. A wire may be touching another wire, touching metal, etc. How did you wire them up? Did you just connect & electrical tape them, use proper connectors, or what?
Need more info.
Just tryin' to help.
Old Sep 27, 2010 | 10:15 PM
Fallen3's Avatar
I've been off at school since I posted, sorry.
I have blown the fuse... I didn't notice earlier, but the horn doesn't work either:P
I'm going to go over everything I did in the morning, and make sure that I didn't mess anything up.. I have a rough idea of where it might have gone wrong though.
Thanks for the help. I picked a horrible time to learn how to do all this...
At the consequence of looking noobish... the fuse is a 10/20 amp one, correct? I can pick those up at any auto parts store?
And an edit:
I just reread what I posted earlier, I'm sorry. It sounds rather rude and unhelpful. I'm sorry if it came across like that.
Old Sep 27, 2010 | 10:42 PM
gotcbr's Avatar
No worries. Hopefully, we'll get it all figured out.
Yep, you're looking for the small 10 amp & larger 30 amp fuses.
Looks like this...
Hope you get it going w/o any problems.
Old Sep 28, 2010 | 01:15 PM
Fallen3's Avatar
Yup. I re worked all the wiring and found that a piece of cable broke through the heat wrap. I redid everything, making sure that everything was working just fine until final install. I also replaced the fuse, and everything works just fine.
Thanks a lot for all the help. I can pick up spare fuses at an auto parts store, right?
Old Sep 28, 2010 | 03:56 PM
gotcbr's Avatar
Sure thing.
Yep, you can get the fuses at auto supply stores. I've found that PepBoys generally keeps those small 10 amp fuses in stock, whereas some of the smaller shops don't always have them.
Glad it worked out ok.
RoosterF3
F2 Tech
14
Apr 10, 2010 09:26 AM
utter05
Jan 22, 2009 01:10 PM
Stugots
May 1, 2008 03:51 AM
dewthedoo05
Sep 4, 2007 09:32 PM
gotcharr
Mar 3, 2006 11:48 PM
