wrecked it,help!
Old Sep 15, 2006 | 07:14 PM
StuntinThe954rr's Avatar
Default wrecked it,help!
whats up?new to the forum and it looks great so far!
well,i was in my parking lot as always,rollin stoppies,practicing,u know,anyways i rolled a stoppie forward,didnt get too hurt but im not worried about me,my bike now wont start...im thinkin tip over sensor,i picked it up imediatley,sat it straight for 20 min,went to turn it on,oil lights are on it wants to start but wont catch and actually start,so can some1 tell me where the tip over sensor is located,io wanna tryt that and i think maybe my oil pump went out?i dont know much as u can tell but i wanna ride!
thanks for the help....
Old Sep 16, 2006 | 12:36 AM
bobjoezx's Avatar
Default RE: wrecked it,help!
well ur tip over sensor is in front, right under and in front of the speedo
Old Sep 16, 2006 | 03:43 PM
fRacer 954RR's Avatar
i have the same problem theres a wire right under the speedo that came off after my accident and i dont know where it goes and i thinkk thats why my bike wont start
ORIGINAL: bobjoezx
Old Sep 16, 2006 | 05:04 PM
some1 said to bypass the tipover sensor,i tryed that,the 2 outside wires and leave the middle hangin?now the bike wont crank,it just clicks and stops
Old Sep 18, 2006 | 12:31 AM
bobjoezx's Avatar
dont mess with stuff u dont know how to do.......
Old Sep 18, 2006 | 06:54 PM
do u kno how to fix itt
Old Sep 20, 2006 | 02:31 AM
sickshifter21's Avatar
you may just have to reset the tipover switch you just turn the key on -off -on a few times and that resets it (should) but id try that before i messed with the wiring
Old Sep 20, 2006 | 06:28 PM
alright thanx
Old Sep 21, 2006 | 02:01 PM
TongWoo's Avatar
Did you flip it upside down...or to an angle where the oil could have run into the airbox and head? If so, you might be hydrolocked. When you were tryin to start it if it turned over and stopped abruptly it's prolly hydrolocked. If so, pull the sparkplugs (and the ignition fuse lol) crank it to get the oil out of the head....
As far as the tip over sensor is concerned.... You just unplug it, then connect the two outer wires on the plug.
Old Sep 22, 2006 | 07:03 PM
i got it guys,it was my tipover, thanks
Mr_Dunev
Dec 21, 2012 01:37 PM
SPEEDCAT911
Apr 28, 2008 09:21 PM
oreo
Jul 1, 2007 05:03 PM
txmorgan
Feb 6, 2007 07:57 PM
sm0ke5150
Sep 24, 2006 10:36 PM
