Right turn signal problem!!
Hi experts!!
My right turn signal works when I hit the switch, but it is switched off normally instate of being lit all the time. I have checked all the connections. They are all properly connected. Can you help me with this issue? Farokh |
RE: Right turn signal problem!!
are you staying the light doesn't stay on when you let off the switch, maybe i am reading it wrong but i dont exactly understand your problem
I think he's saying his lights are running lights and the bulb works when he uses the turn signal but it's turned off when he's not using the blinker
are they stock or aftermarket.. because aftermarket is usually 2 wire, stock is 3 so u got to figure out if u want running lights or blinkers, but i dont thnk that's what u mean
My turn signals are stock with three wire. Sorry for being confusing, Yes i mean it turns of when i let the blink go instant or running.
taht might be something in the switch but i am not exactly sure i would kinda have to be there and check it out... but i am thkning switch
relevent question: how do you take off the blinkers on both sides? does it require removal of the entire front fairing?
eh depends usually just take some of it apart and see if u can get to the wires, got to buy the right size, and make sure u wire them up right
