02 900/954 crank no start issues
Edit; gottcha you mean timimg ,dont think so but you could check that out
Had the exact prob, had fuel in tank, has good spark, was running before, was hearing the fuel pump kicking in pre-start? & well for me it had to be fuel, so i started with the pulling of the fuel tank & had a little of grunge which I totally cleaned out, & fuel pumps are cheep as so i fitted a new one of them, But when i pulled the fuel filter I discovered it was clogged with this rust colored sludge & using a 50ml syringe hooked up to a 8mm tube i back flushed the filter with 91 ron until all the sludge was 100% cleared, & put back the fuel pump & filter assembly & it started up 1st go!! . These bikes are over 15 years old, & because the fuel filter is inside the fuel tank, like my one it had never been looked at . I started off with list # 1 of fuel fix's & by luck, i got it, & it cost me $12.75 Australian. After that I ended up grabbing an on line a injector cleaning tool & spray can of throttle body cleaner & replaced all the 6mm tank to & from fuel rail hose's & clamps, & pressure cleaned all the injectors, & the improvement from this service job gave me back this weapon 954rr to it's old self & it only cost me $32 Aussie bucks. Some times the 1st fix try gets it, C.W
954Luigi
Aug 13, 2013 02:09 PM
