02 900/954 crank no start issues
Old Jun 14, 2018 | 10:20 AM
  #21
Thisguy's Avatar
Originally Posted by 74demon
Maybe try reloading the MAP, or disconnecting it and see what happens.
I've seen them malfunction and cause problems.
reloading the map in the power commander? Idk how to do this. I'm a class 8 diesel mechanic so I know engines pretty good but need to working on bikes
Old Jun 14, 2018 | 11:30 AM
  #22
74demon's Avatar
You need to download the correct one from the web and load it by connecting it to your computer. If you have a custom MAP, it gets more complicated.
It would be better to just disconnect it and return the system back to stock for testing purposes.
Old Jun 14, 2018 | 11:56 AM
  #23
CaBaRet's Avatar
Could be on a winner there Demon
Old Jun 14, 2018 | 12:59 PM
  #24
Thisguy's Avatar
Ok new plugs in. Unplugged the power commander, swapped around the relays, and fuel tank with fresh fuel. Cranks but no start. Mil light stays on still fi light goes out once pump primes up and oil light stays on. What now boys
Old Jun 14, 2018 | 01:28 PM
  #25
74demon's Avatar
When you took out the PC, did you connect everything back to stock?
I'm not sure where to go from here. It should be running.
Old Jun 14, 2018 | 01:36 PM
  #26
Thisguy's Avatar
yes everything is hooked up. Did backfire once tho I forgot that part, but yeah idk what to do.
Old Jun 14, 2018 | 02:01 PM
  #27
CaBaRet's Avatar
Even a backfire helps, have you done any work around the Cam Pulse Generator if so have a look around that area
Old Jun 14, 2018 | 02:10 PM
  #28
Thisguy's Avatar
no I haven't done any work to it before the no start issue
Old Jun 14, 2018 | 02:29 PM
  #29
CaBaRet's Avatar
Can you unplug the IAT and the MAP sensors , turn the engine over for a few seconds and see if it shows up the fault, this would'nt stop the bike from starting if it could but it would generate some faults on the dash
Old Jun 14, 2018 | 02:38 PM
  #30
Thisguy's Avatar
yes I have done checked that it does put out codes of I unplug them
