02 900/954 crank no start issues
Hi just to make it clear in my mind, you have spark ,air , fuel, what do the plugs look like, and the red light on the instrument panel is it the Fi light or the oil light, a steady Fi light points to the ECU, can you run the procedure to erase faults and then see if it sets any up ,or have you tried that, can you borrow a pals ECU to test ( I'm assuming your in the USA)
Yeah I got everything needed to run but it's not idk wtf but No it's the mil light beside the netural light. The fi light goes out once the fuel system is primed, idk if that's okay or not. That's where I am now I feel like compression isn't the issues honestly but I'm going to check it I feel like it is a sensor keeping it for running since it happened randomly. Also have already tried another ECU with the same outcome
maybe try swapping some relays round, headlight relay with the fuel cut-off relay, maybe isolating usual suspects, what do the spark plugs look like , are the wet, have you tried turning the engine over continuously for 10 seconds at WOT to clear the cylinders, is your headlight harness still connected
Are the plugs fouled with gas? Can we assume that it's actually gas in the tank and not water or diesel?
It's not going to be a compression issue. If it was, it would sound really different when it's cranking.
According to your findings, you have everything to make it start.
Are the plugs fouled with gas? Can we assume that it's actually has in the tank and not water or diesel?
