02 900/954 crank no start issues
Old Jun 14, 2018 | 02:45 PM
  #31
CaBaRet's Avatar
Right just wanted to make sure the ECU was reading them, have you still got the BAS, Clutch and Sidestand switches bypassed
Old Jun 14, 2018 | 03:24 PM
  #32
74demon's Avatar
The BAS cuts the fuel pump. The other things keep it from cranking.
Old Jun 14, 2018 | 04:51 PM
  #33
Thisguy's Avatar
I bypassed the base for testing but it's working fine the other 2 or not bypassed I can do that. Which pin do I jump
also what is spec on compression for these bikes?
Old Jun 15, 2018 | 01:09 AM
  #34
CaBaRet's Avatar
Yes I know that Demon ,but just trying to get the bike back to base with no other intermittent problems that might cause this, my thoughts are that this is a wiring fault and everything that can cause a no start should be taken out of the loop
Old Jun 15, 2018 | 01:15 AM
  #35
CaBaRet's Avatar
For the side stand join the two wires , for the clutch undo the two fasteners at the clutch lever and insert a wire to them both, on the main harness check all connectors and the central earthing points , there is a large one in the harness on the right hand side fully taped over ,see if that one has been affected
Old Jun 15, 2018 | 01:50 AM
  #36
CaBaRet's Avatar
Manual states 174psi
Old Jun 15, 2018 | 02:02 AM
  #37
CaBaRet's Avatar
This is what a bad central earthing point looks like
Attached Thumbnails 02 900/954 crank no start issues-earth-2.jpg
Old Jun 15, 2018 | 02:26 AM
  #38
Thisguy's Avatar
he that's a bad time there
Old Jun 15, 2018 | 02:35 AM
  #39
CaBaRet's Avatar
Sort of stuff that can happen and as you tried a pals ECU and got the same fault, and you proved your ECU is reading faults , it has to be electrics , but trying to find that wiring fault is the biggy, getting a reaction even a back fire is show that the plugs are trying to fire, but before we go any further is your battery up to scratch (a good one)
Old Jun 15, 2018 | 02:44 AM
  #40
Thisguy's Avatar
I have to keep it on a charger cause its weak but turns over fine. I talked to some of my co workers today and they seem to think it jumped time does that happen much with these things
