Possible Exhaust Leak
Good Evening All,
I have the Jardine Dual Outlet Exhaust and believe I have a slight exhaust leak where the s-pipe conects to the header. I positioned the s-pipe all the way down on the header pipe stop ring and made sure the clamp covered the connection. Itightened the clamp as much as possible but am afraid to keep going for fear of the clamp screw breaking. The folks at Jardine said the carbon should seal any minor leaks after the first 100 miles or so, but ithas not happened as of yet. Has anyone else had an issue with this exhaust, or maybe have suggestions on how Imay fix it?Thanks for any assistance.
Thanks,
Sprout
Thanks,
Sprout
ORIGINAL: Tahoe SC
if you suspect a leak then use some RTV high temp sealant at the joints.
i use ultra copper high temp.
