Exhaust Leak
Old Aug 21, 2007 | 02:53 PM
ryandrosa's Avatar
Default Exhaust Leak
I have a Two Brothers slip on and there is a gap between the where the slip on and the mid pipe meets. Its a small little gap but I can feel some exhaust leaking out and sometimes moisture spits out. I've tried every possible way of adjusting the slip-on so there is no gap but no luck. Should i be concerned of this or is this normal with all slip-ons?
Old Aug 21, 2007 | 02:58 PM
Tahoe SC's Avatar
Default RE: Exhaust Leak
there shouldn't be any gap or leaks. it is not normal.
are you saying that themid pipe from the slip ondiameter is much bigger than the end of the header?
did they provide a clamp with it? if so, crank that sucker down.
if there is still a gap, try using high temp RTV or send it back.
Old Aug 21, 2007 | 03:32 PM
bootleg___'s Avatar
You should try cranking down the clamp like Tahoe said. That should do it if the diameter isn't a huge difference.
Old Aug 21, 2007 | 03:37 PM
ninetyfivehp's Avatar
i put some high temp permatex exhaust sealant (orange stuff)on the midepipe and tightened the band clamp to the recommended spec. 17lbs/ft. no leaky
Old Aug 21, 2007 | 05:14 PM
Firefly's Avatar
+++1 on the RTV HIGH TEMP SILI sealant. I had that issue with my Micron slip on. THe stock pipe has a gasket that slides over the end of the Header ( the Connectiing point beneath the bike) AFtermarket Slip on pipes Wont fit with the stock Gasket on the header end. JUST put a Bead of HIGH TEMP RTV around the the header the inside of the slip on end that slides over the stock header/ Put it back together, Torque it down , You should be Golden. I Did this and was Golden.
Old Aug 22, 2007 | 09:52 AM
Tahoe SC's Avatar
ORIGINAL: ninetyfivehp
WTH? you telling 'band clamp' stories? should it start like "one time in band clamp"...hHHAHAHHAHAHHA
Old Aug 22, 2007 | 12:01 PM
ryandrosa's Avatar
The connection between the slip on to the mid pipe is a little loose. I guess I can just put some high temp sealant there.
cschew
Dec 22, 2011 03:04 AM
johnnyx
Sep 14, 2009 09:08 AM
simtech
Jun 12, 2007 01:06 PM
SproutRR
Jun 6, 2007 07:16 PM
907hondaf3
Apr 14, 2006 07:53 PM
