Possible Exhaust Leak
Old Jun 5, 2007 | 03:31 AM
SproutRR's Avatar
Default Possible Exhaust Leak
Good Evening All,
I have the Jardine Dual Outlet Exhaust and believe I have a slight exhaust leak where the s-pipe conects to the header. I positioned the s-pipe all the way down on the header pipe stop ring and made sure the clamp covered the connection. Itightened the clamp as much as possible but am afraid to keep going for fear of the clamp screw breaking. The folks at Jardine said the carbon should seal any minor leaks after the first 100 miles or so, but ithas not happened as of yet. Has anyone else had an issue with this exhaust, or maybe have suggestions on how Imay fix it?Thanks for any assistance.
Thanks,
Sprout
Old Jun 5, 2007 | 01:15 PM
hondadriver4life's Avatar
Default RE: Possible Exhaust Leak
i just got my rt1 installed a few days ago and havent noticed that it was leaking. how did you find out that you had an exhaust leak?
Old Jun 5, 2007 | 05:13 PM
Tahoe SC's Avatar
if you suspect a leak then use some RTV high temp sealant at the joints.
i use ultra copper high temp.
Old Jun 6, 2007 | 05:43 PM
CBRCRF's Avatar
ORIGINAL: Tahoe SC
I’ve only done exhaust on my dirt bike. The instructions said to use a high temp sealant. I thought you always had to use it when doing an exhaust?
Old Jun 6, 2007 | 07:16 PM
Tahoe SC's Avatar
you should use it just in case but most don't use it unless it leaks. the fit on some of the pipes are just amazing! but the cheaper stuff still fit crappy.
cschew
Dec 22, 2011 03:04 AM
johnnyx
Sep 14, 2009 09:08 AM
ryandrosa
Aug 22, 2007 12:01 PM
simtech
Jun 12, 2007 01:06 PM
907hondaf3
Apr 14, 2006 07:53 PM
