Exhaust leak
Old Sep 4, 2009 | 10:36 AM
johnnyx's Avatar
Default Exhaust leak
I got cut off in a twisty the other day, and went to hit the horn, but screwed up and hit the starter. The bike reved pretty high, but it was only for like a second. After that, the bike started having trouble accelerating. I go about 3 blocks, then it backfires, and everything is back to normal. About halfway home though, I start smelling exhaust coming up from the engine compartment whenever I'm stopped at a light. It's been a few days, and hasn't gone away, though the intensity varies greatly. I inspected the manifold all the way down, and can't find any holes. Ideas?
Old Sep 4, 2009 | 01:12 PM
Northernfirepower's Avatar
Check and make sure your plugs and carb fittings are tight.
Old Sep 8, 2009 | 11:06 AM
johnnyx's Avatar
Yeah, both are tight, I reseated both anyway, just to bee sure. :/ I'm thinking head or exhaust gasket may be blown?
Old Sep 8, 2009 | 11:56 AM
kjohnson's Avatar
Pop the cap on your runoff coolant tank,located on the throttle side of the bike,just above the right rearset.Take a wiff.If you smell exhaust fumes,your head gasket may be done.
Old Sep 9, 2009 | 10:59 AM
johnnyx's Avatar
That's a great idea. Will do.
Old Sep 10, 2009 | 01:56 PM
johnnyx's Avatar
Coolant smelled oK. Came out from lunch today and the smell was gone, but now thw bike sounds like a V-twin; really loud sound from exhaust. Lost a bit of pull off the line, but seems to work OK other than that. Now I'm REALLY worried. :/
Old Sep 11, 2009 | 07:21 AM
kjohnson's Avatar
If in fact you do have an exhaust leak,you will lose some power.Easy fix.
I have a few pipes I'll be selling soon.If you want one,lemme know.
Old Sep 11, 2009 | 01:02 PM
johnnyx's Avatar
Problem fixed itself, somehow. I rode it for about a mile, stopped to get gas, and when I started up again, all was well. Still don't smell the exhaust, so that's good. Still, something is wrong and now the clues are gone. :/
Old Sep 11, 2009 | 01:03 PM
johnnyx's Avatar
Well, it's not stock, it's the Yosh race exhaust, so not cheap. Wouldn't it make more sense to repair it?
Old Sep 12, 2009 | 09:50 AM
kjohnson's Avatar
Yeah,repair is good.Yosh sells can parts so fixing isn't difficult.
