Exhaust Leak
Old Dec 17, 2011 | 06:23 PM
cschew's Avatar
Default Exhaust Leak
I just installed a two brothers m-2 canister slip on to my 2004 f4i. I removed the gasket between the midpipe/headers. I slipped on the new midpipe and mounted everything.
It sounds great! But I noticed that there is a little steam of air leaking out of where the midpipe connects to the headers. After about a minute of idling, some water started to drip out too.
Any suggestions? Is that bad? I read that some slip-ons have some leaks. What are the consequences of having this leak?
Any help would be great!
Thanks!
Old Dec 17, 2011 | 07:48 PM
OZZY_F4's Avatar
might seem like a dumb question but did you reassemble it with gasket in place between the header and mid pipe? becauase far as i know they shouldn`t leak at all, the water coming out is quite normal, but ussualy comes out the muffler.
Old Dec 18, 2011 | 12:56 AM
cschew's Avatar
The Two brothers instructions says to remove the gasket between the headers and the midpipe.
http://www.twobros.com/Cust_Service/..._VALE_Inst.pdf
3. Remove the hardware that holds the stock muffler at the
passenger footpeg bracket. Take off the muffler. Be sure
to remove the exhaust gasket (header/muffler junction)
as our system does not use it
Old Dec 18, 2011 | 07:54 AM
vegas_rebel's Avatar
My Dan Moto exhaust also leaks in that same area for pretty much the same reason. I haven't noticed any adverse effects in the last 6 months or so, though I've also wondered if there was any non-obvious bad stuff happening because of it.
Old Dec 18, 2011 | 01:20 PM
cschew's Avatar
Ya I'm worried that I might be "hurting" the bike without even knowing it.
Does anyone know if having the leak will hurt the bike in any way?
Old Dec 18, 2011 | 07:35 PM
wagzhp's Avatar
Nope, it will not harm anything.
Old Dec 21, 2011 | 02:57 AM
OZZY_F4's Avatar
I`ll second that
Old Dec 21, 2011 | 03:15 PM
An01InAZ's Avatar
Only thing you will harm is a couple HP. but not a huge drastic change. im experiencing a leak this morning. darn two bros pipes. haha but mine is at the midpipe
Old Dec 22, 2011 | 03:04 AM
OZZY_F4's Avatar
One other thing you could is remove the mid pipe clean the flanges and use high quality high temp exhaust or simalar sealent run a bead around and clamp it up. i use this on my 2 stroke motorcross bikes and on header flanges than constantly leak.
johnnyx
Sep 14, 2009 09:08 AM
ryandrosa
Aug 22, 2007 12:01 PM
simtech
Jun 12, 2007 01:06 PM
SproutRR
Jun 6, 2007 07:16 PM
907hondaf3
Apr 14, 2006 07:53 PM
