Sudden increase in vibes?
Old Mar 12, 2019 | 12:31 AM
DSA's Avatar
DSA
Default Sudden increase in vibes?
Hi,
I've got a '93 with 63k miles. In the past few days, I feel like I can feel the vibes more. Through the grips, the seat, the pegs, everywhere. I suspect these are engine vibes as opposed to road vibes (pulling clutch at speed seems to reduce them). What could be causing this? Bike feels as strong as ever, no other sign of anything being wrong.
Thanks!
Old Mar 12, 2019 | 12:52 AM
CaBaRet's Avatar
Would say that if pulling the clutch in gets rid of the vibrations then we should be looking at the clutch, with the drive disengaged no vibes ,with clutch in vibes, so some where on the transmission from the clutch to the rear, as long as all the other factors are ok (chain tension ,sprockets ok) could be looking at a clutch bearing, hard to say at this stage but check the other factors first,
Old Mar 12, 2019 | 10:50 AM
DSA's Avatar
DSA
Thanks for the reply. Not sure it's the clutch - if I leave it pulled in and rev the engine, the vibes come right back. You can really start feeling them around 3k rpm, which is odd because this bike is usually insanely smooth under 5k. The chain is reaching the end of its life (according to the wear meter on the swing arm), but it's currently tensioned correctly. Guess we'll see if a new chain/sprockets fixes it, but seems unlikely.
Old Mar 12, 2019 | 01:10 PM
74demon's Avatar
Could you be feeling a misfire? A motor that isn't hitting on all 4 will definitely vibrate.
Old Mar 12, 2019 | 02:55 PM
DSA's Avatar
DSA
Could be - how would I go about confirming/diagnosing that?
Old Mar 16, 2019 | 03:27 PM
TimBucTwo's Avatar
Look here
https://cbrforum.com/forum/how-tos-8...stment-107818/
Old Mar 16, 2019 | 07:16 PM
DSA's Avatar
DSA
Thanks for the suggestion! Did that - it is noticeably better, but still not as good as it used to be. It seems to be worse on the left side of the bike - the left grip and peg seem to buzz a touch more than the right ones. Maybe it's time for that valve clearance check an adjustment that I keep procrastinating on.
redbaron1728
Apr 29, 2012 08:07 AM
estate4life
Sep 2, 2011 12:30 PM
fastcbr
Mar 4, 2009 05:44 PM
yacobie
Apr 30, 2007 01:59 PM
HighRevver
May 30, 2006 06:36 AM
