Clutch problem?
Old Apr 29, 2012 | 12:00 AM
redbaron1728's Avatar
Default Clutch problem?
Ok, so I know my clutch is slipping and am planning on putting in a new clutch kit here in the next few weeks. Now, when I went to top my bike out today it was weird, it wouldn't go over 135MPH. It's a 92 f2. I could understand that if I was redlining, but even at full throttle the bike wouldn't go past 10K RPM. I was wondering, is that because my clutch is slipping? Or some other reason? The gearing is all original and I have absolutely no problems other than the clutch. Also,\ I'm not sure if there's a limiter or not on the bike, any ways to check? Thank you!
Old Apr 29, 2012 | 08:07 AM
There are any number of possibilities as to why your bike wouldn't go past 10K RPM if you were in 6th gear. A slipping clutch though isn't one of them. I can't speak for any particular bike, but it's a matter of performance. What is the overall running condition of the bike ? Does it pull to redline in lower gears ? How well has the engine been maintained ? Valves adjusted, carburetors cleaned, adjusted, synchronized ? Air filter replaced ? History of the bike ? Has it been ridden hard all its life ? Put it on a dyno ?
A slipping clutch would cause your engine RPM to go higher more quickly than the speed of the bike.
mlrtime99
Oct 10, 2007 03:11 PM
smak_blaze
Mar 30, 2007 05:40 PM
lowrinlife
Jul 30, 2006 02:18 PM
lowrinlife
May 27, 2006 12:18 PM
lowrinlife
May 26, 2006 09:21 PM
