How-To: Mechanical This section is ONLY for sharing step-by-step instructions on how you did a project. Please post tech related questions in "General Tech". Adherence to this policy will be strictly enforced by the staff ...
HOW TO: Change your CCTL with PICS!!!!
Old Apr 29, 2019 | 09:42 AM
  #61
Jayblade's Avatar
Default Tdc
Great post, kudos to you.
Im about to fit a manual cct on my 1998 900rr fireblade and the instructions say to manually put the timing to TDC (top dead centre) nut noticed you didnt do that?
Originally Posted by pittsm
I have been needing to do this for some time now and I finally decided to sit down and get it done and I figured I'd do everyone else a favor and document it as I went. Since to my knowledge the only other one with pics is the one that shows the manual cctl, I figured this would help fill in some gaps.
Let me start by saying I am by no means an expert with motorcycles. This is my first bike and the first time I have actually worked on it. I grew up with atv's and have done lots of work on them, so the knowledge kinda transfers over. Now to mention this was a super easy thing to change.
If anyone sees something I left out or something I did wrong please let me know and i'll change the how to since I'm assuming lots of people in the future will be using this.
The bike in question is an 03 CBR F4I. The directions might vary slightly on the banana seat models, but should still be super easy to figure out. Also, disregard the fact that my bike is rashed and dirty. Just deal with it, i do.
NOTE: I'm not responsible if any mistakes are made or if you damage something in/on your bike, always consult with your dealership if you are not sure about something.
Important: Have the bike in Neutral when performing this and do not move the chain or wheel.
Also, the total install time took me two hours from the time I walked out in the garage until the time I took my test ride.(It was rainy, but i didn't care. I had to know. lol) The difference was night and day. Went from being all rattly and noisy to whisper quiet. So amazing. Now I can ride around town without having to try and keep it between certain rpm's for fear of humiliation.
That being said, here goes.
__________________________________________________ ____________________________
Step 1 - Remove the right lower cowl. It is attached with 6 screws shown in picture (5mm), 2 screws behind the front tire(phillips), and 3 trim clips, two on bottom of bike and one behind the front tire up high.(phillips screwdriver will take these out, mine kinda fell out, lol)
Attachment 53305
Step 2 - Remove the right air duct cover. It is attached with 2 screws shown in picture (5mm). A tip here is to be careful not to lose any of the screws or any of the rubber grommets that the screws screw into down in the motor, it'll be a pain in the butt to find it and get it back out.
Attachment 53306
Step 3 - Remove your seat. It is held by two bolts on each side of the back under the foam. Just pull it back some and you'll see it.
Attachment 53307
Step 4 - Get the tank out of the way. Start by taking out the two bolts in the back that were under your seat. (I used a t40 torq bit, but a allen wrench or equal size would work)
Attachment 53308
There are two more bolts up front under the bars that need to come out also.
Attachment 53309
Finally, take the 5mm screw out of the left air duct cover and the tank will be free.
Attachment 53310
Step 5 - Set your tank off to the back left of the bike and then lift up the rubber flap and tuck it under the tank to get it out of the way. I used rags on the back of the tank and up by the bars to keep it from rubbing on the paint.
Attachment 53311
Step 6 - Unplug this harness and push it back out of the way.
Attachment 53312
Your CCTL is now visible.
Attachment 53313
Step 7 - Start loosening the top and bottom bolts holding on the CCTL. The top one can be accessed with a 3/8 or 1/4 ratchet, extension, angle attachment, and 5mm allen socket. Go in through the top as shown in pic.
Attachment 53314
The bottom one is a bit trickier. Use the same setup and go in through the access hole as shown in pic. Note that you must use the 1/4 attachment here to be able to make the angle. I couldn't get the 3/8 extension to work. BE PATIENT!!!!
Attachment 53315
You can stick your hand through the gap above the cctl and kind of guide the tool into the screw head. Luckily mine weren't very tight and came our pretty easy. The CCTL will come out through this gap as well.
Attachment 53316
Here is a pic of where the CCTL was. Make sure the old gasket came off completely.
Attachment 53317
Here is a pic of the old and new CCTL's. Note the old one has one blue dot and the new one has two blue dots.
Attachment 53318
Step 8 - Take the two screws and washers out of your old one and put them in your new one. Don't forget your new gasket! Reinstall the new one the same way you took the old one out and tighten down the mounting screws.
Step 9 - Remove the retainer clip. Just take some needle nose pliers and reach down there and pull on it. It slides straight out. At this point you'll hear it "snap" into place.
Attachment 53319
Here is a pic of what the clip looks like removed.
Attachment 53320
Step 10 - Don't forget to take the old screw and washer out of the end of your old one and put it in the new one where the clip previously was.
Attachment 53321
That's it, your done!! You can now start to put the bike back together in reverse of how you took it apart.
Don't forget to plug your harness back in!!!!
If I missed anything or left questions, let me know and i'll edit the post.
Old Oct 25, 2021 | 05:13 PM
  #62
Itseitherofforon's Avatar
Default Hey thanks
This is awesome so appreciated. Will be doing mine next week on my 01 38,000 miles. Appreciate you man looks easy
Old Oct 26, 2021 | 05:50 PM
  #63
Doc Samson's Avatar
The only thing I'll add, just in case it wasn't mentioned, is to stuff a towel or some fabric big enough to provide a firm "underneath" before you get started! Losing any of those parts down into the frame sucks big time!
Old Oct 26, 2021 | 05:57 PM
  #64
LOL, is that the voice of experience talking ?
Old Oct 26, 2021 | 07:53 PM
  #65
Default Thanks doc
hey thanks for the tip I'll make sure to do that I also bought myself some magnetic sticks so I can have it on the Bolt as I'm taking it out
Old Oct 27, 2021 | 04:12 AM
  #66
Doc Samson's Avatar
Oh yes! Dropped that end bolt about 4 times trying to get it threaded back in and had to go "hunting" with a flashlight and a...
LARRYTHEPIRATE
Nov 12, 2017 06:55 AM
thirdgenlxi
May 23, 2011 09:09 AM
marsolais
Jun 28, 2010 08:12 PM
thirdgenlxi
Jun 27, 2008 07:13 PM
bigcha40
Jun 10, 2007 12:35 AM
