Wiring issue : constant cranking
Old Dec 2, 2022 | 07:46 PM
motorcyclemike's Avatar
Default Wiring issue : constant cranking
Hey y’all, just picked up this project 95’ 600F3 for a steal.
now I may know why
First off, 15 years of motorcycle building in my blood. I’m not scared of anything on these things but wiring isn’t my forte.
I went to crank the ride for the first time and it cranks, but it just keeps cranking. Kickstand safety, kill switch, even turning off the ignition didn’t get it to stop cranking. Just kept going non stop until I disconnected the battery.
obviously the harness has been f’ed with. I’m going to start tearing down the harness tomorrow but has anyone run into this? I’ve never had a bike continue to crank even after the starter has been released and the kill switches/ignition turned off. Doesn’t make sense.
Old Dec 3, 2022 | 01:32 AM
dannoxyz's Avatar
I had issue once where start-button was stuck on. But that would only crank when key was ON.
In your case, it might be starter-solenoid with stuck internal contacts between B & M terminals.
Easy enough to test. Measure resistance between B & M terminals with starter solenoid removed from bike
Old Dec 4, 2022 | 08:12 PM
thanks for the input! Turns out it was a 30A fuse that was blown in an external fuse location off the positive battery lead.
swapped it out and seemed to fix our issue!
Now if anyone has a source for plug wires ….
Old Dec 5, 2022 | 01:33 AM
dannoxyz's Avatar
Weird that blown fuse would cause solenoid to crank all the time...
There may be multiple issues with wiring...
Old Dec 5, 2022 | 01:50 AM
dannoxyz's Avatar
While you can get used sets off fleaBay and other places, would be better to get new. You can certainly get part to make your own:
https://www.vintagecb750.com/products/5/electrical
But for something like this, I think it's simplest just to do coil-on-plug conversion. Like this:
https://cbrforum.com/forum/how-tos-8...ensive-139800/
Note there's some errors in wiring diagram. Final version that works is this:
You can get set of coils + harness for decent price: https://www.ebay.com/itm/185614510065
DC1990
Jul 6, 2022 10:39 AM
specter4
Feb 18, 2022 07:44 AM
biffle87
Jul 3, 2019 12:36 PM
BE13
Jan 6, 2018 09:20 PM
89skullz600
Oct 8, 2010 05:45 PM
