Removing decals from F3
Old Feb 17, 2006 | 09:12 PM
coleyo's Avatar
Default Removing decals from F3
Ok, I just need the process and pics if you got em
Old Feb 17, 2006 | 09:21 PM
cjbettis's Avatar
Default RE: Removing decals from F3
pulled all mine....no pics during process...but main tip I can give you it DON'T use a metal scraper/razor blade.....use a plastic one and a hairdryer
totally worth it
Old Feb 17, 2006 | 09:31 PM
coleyo's Avatar
how long did it take. So all I have to do is heat the decal with a blow dryer and scrape it off with a plasic razor? Once heated does it peal easy?
Old Feb 17, 2006 | 09:54 PM
scotty8583's Avatar
Once the decal is heated up it will peel back easy. Don't get it so hot it starts to bubble up though! Just go really slow and try to keep it all in one piece to keep the glue from sticking to the panel. If there is some residual glue use a very mild solvent or rubbing alcohol. Good luck, cant wait to see th pics.
Old Feb 17, 2006 | 10:00 PM
cjbettis's Avatar
wd40 works good too for residue...I did mine without the heat..took way longer and found out after the fact
Old Feb 17, 2006 | 10:36 PM
arkas's Avatar
There's a product on the market called Goe-gone. It is made for taking off decals or anything that sticks on like stickers etc.... It wont arm your paint in fact that's exactly what is made for. You apply the Goe-Gone and wait 5-10 minutes and then it just comes right off. I have used it on my old bike and it worked like a charm. Not that expensive either, I paid $5 for a 150ml bottle. You can pick this stuff up in any hardware store like Home Depot, home hardware, Rona etc..... there are other brand names also just ask your local hardware rep and he will point you in the right direction
Old Feb 18, 2006 | 04:20 PM
jaboyak's Avatar
goo gone helps a ton. Taking off the stickers is a long, annoying process, but worth it in the end. IMO
Old Feb 18, 2006 | 04:35 PM
F4Isvt's Avatar
use a bic lighter it sounds really stupid but you can push as hard as you want and it wont damage the clear. It takes a while just be patient. I used a bic lighter and stoners invis a glass to remove the goo. You can't even tell they were ever there.
FITZ
Apr 8, 2008 02:54 PM
Quick6Atl
Mar 2, 2008 10:54 AM
Dj_Squatch
Feb 28, 2008 04:44 PM
118367s
Feb 14, 2008 07:19 AM
RR RIDER
Aug 11, 2005 02:39 PM
