removing decals
Old Feb 13, 2008 | 08:32 PM
118367s's Avatar
Default removing decals
how do you do it
Old Feb 13, 2008 | 08:58 PM
yamadog1507's Avatar
Default RE: removing decals
are you refering to decales under a clear coat, or over a clear coat?
Old Feb 13, 2008 | 10:49 PM
ffingers's Avatar
Registered Users
the ones not on the tank...that is not under a clear coat....there's a couple of ways but the BEST way...the way i removed mine is a two step process....
1) get a blow dryer or heat gun and heat up the sticker...will allow it to pull off...do it slow or it will tear....all it's going to do is remove the actual sticker...you'll have an adhesive residue where the sticker was...which leads to step two...
2) goo-be-gone...get a ton....put it on...try not to let it run..let it sit....then rub and rub and rub..with a non-scratch rag from a detailer or auto parts store....keep putting on the goo until it all comes off....
3)...move onto the next...
Old Feb 14, 2008 | 05:04 AM
Volksdragg's Avatar
Some auto detailing waxes and polishes takes off the adhesive just fine.
Old Feb 14, 2008 | 07:19 AM
WD-40 will take off the goo too, or denatured alochol, and its gentle on the paint
FITZ
Apr 8, 2008 02:54 PM
Quick6Atl
Mar 2, 2008 10:54 AM
Dj_Squatch
Feb 28, 2008 04:44 PM
coleyo
Feb 18, 2006 04:35 PM
RR RIDER
Aug 11, 2005 02:39 PM
