No volts to the stick coil leads that would have connected to the OEM coils
Old Aug 29, 2022 | 06:17 PM
  #61
MN Hurricane's Avatar
Originally Posted by dannoxyz;[url=tel:1351490
1351490[/url]]This is great work!!!
1. you've confirmed sub-harness between Spark Unit and pulse-generator have no shorts AND all wires are intact and not broken.
2. both pulse-generators are within spec. Manual states 460-580 ohms
3. so that leaves Spark Unit as lone perp!!!
i was so ready to tear into the pulse generator too! How many steps ago did you know it was the spark unit?! 😂
Old Aug 29, 2022 | 06:29 PM
  #62
I wonder if I have to use a used spark unit or if someone makes an aftermarket one. I assume I can’t fix it myself or with a little help from my friends. Time to do some digging around. I want to thank you again for all of your help, time, patience and teaching me some things …Ok, a lot of things! I don’t know if the bike being laid down on that same side would have damaged the spark unit, but there are a couple spots where the metal is flat when it shouldn’t be.
Old Aug 29, 2022 | 06:43 PM
  #63
3. so that leaves Spark Unit as lone suspect!!!
Makes sense as it ran rnelson5 in circles with fuel-pump not working. Spark Unit wasn't sending spark triggers back then. So no spark and no fuel-pump!
4. One final test and we can confirm Spark Unit dead:
- unplug both connectors from Spark Unit and confirm terminals on harness and Spark Unit are intact and can make full contact
- measure resistance from grn wire to chassis-ground. ohms = ???
00.3 green wire to ground
mall connectors are clean and tight fitting
what is this 3 wire thing behind the spark unit?
Old Aug 29, 2022 | 11:50 PM
  #64
dannoxyz's Avatar
That's flasher-relay for winkers. With it disconnected, using winkers shows no lights right?
Old Aug 30, 2022 | 01:54 AM
  #65
dannoxyz's Avatar
I suspected it when reading rlnelson5's post about fuel-pump issues. But couldn't rule out wiring or pulse-generators as contributors. Apparently, '87 Spark Units were more reliable as you never hear reports of those going bad. This '88 coincided with World-wide issue with massive batch of defective electrolytic capacitors being sent to market. Affected everything from phones to computers, to stereo systems to auto/moto ECUs.
I've thought about replacing these old Spark Units with modern ignitors from Accel or Delco, but there needs to be more logic and memory involved to generate 2D ignition curve.
Here's likely replacement: https://www.ebay.com/itm/185253637346
Once confirmed running, you can crack open old unit to see what's wrong. Probably bloated, leaking and busted-open capacitors.
Old Aug 30, 2022 | 08:09 AM
  #66
Do you know/think I would benefit from finding a unit that specifically states it is from an 87 as opposed to one that indicates 88?
Old Aug 30, 2022 | 11:56 AM
  #67
dannoxyz's Avatar
Yeah, good idea on looking for '87. Although by this time, any '88 unit that's going to fail will probably have done so. Any '88 unit you get will most likely be fine. Most of these vendors will give you 30-day warranty to try it out. Might even be able to repair original one by then to have spare.
1987-88 Spark Unit = 30400-MM5-006
Old Sep 3, 2022 | 05:36 PM
  #68
1351490]This is great work!!!
Makes sense as it ran rlnelson5 in circles with fuel-pump not working. Spark Unit wasn't sending spark triggers back then. So no spark and no fuel-pump!
@dannoxyz you did it!!!! Thanks for the guidance and making me do all this testing!
you are an electrical genius!
https://youtube.com/shorts/E5y-4VGvXpI?feature=share
Old Sep 4, 2022 | 12:36 AM
  #69
dannoxyz's Avatar
Woohoo!!! You did amazing work with all this troubleshooting using remote instructions!
So incredible with being able to track it down to single bad component! No mass shotgunning of parts needed!!! Feels awesome to bring back these classic bikes!
Larshurricane
Aug 3, 2022 10:50 PM
paulwarrendublin
Jul 19, 2013 12:10 PM
7starF2
Apr 10, 2013 04:53 PM
chron929
Mar 1, 2009 12:02 PM
eurobeaner
Feb 21, 2008 12:18 PM
