Clutch Cable is over extended ?
Old Apr 29, 2017 | 07:32 PM
Maybe the cable is broken somewhere inside the sheath. Do you see arm move on the other end when you squeeze the clutch?
Are yoi positive the other end is connected?
Old Apr 30, 2017 | 06:19 AM
wes 17's Avatar
Ok. You need to find the other end of the cable. Try to follow it down, if not. Try this then. Disconnect at the handlebars and see if you can pull it up and push it down, listen, and if it's disconnected you might be able to hear it. I think it's either snapped (prob not) or become disconnected from the lower arm.
The clutch pivot arm is on,or very close to the clutch cover.
Old Apr 30, 2017 | 07:36 AM
doooooooom's Avatar
The clutch pivot arm is on, or very close to the clutch cover.
So I removed the lever, and tried to pull the clutch cable that was connected to the lever, so what did I get is that amount of wire as you can see in the picture when I push it, it will just go inside till it's not visible ( not sure if this what you meant in your message)
In the picture, you can see that this is how much extra cable I am getting, so when I am installing the lever and tightening it on its place there is no tension or anything because of that extra length I got, and if I put the cable inside it just comes out
Old Apr 30, 2017 | 05:05 PM
wes 17's Avatar
I still think it's not connected correctly at the other end. Could you post an image of it for us to check.
Put the lever back on and image both ends.
Could you also clarify what bike and year you have, cheers
Old Apr 30, 2017 | 05:09 PM
doooooooom's Avatar
Honda CBR600rr 2012
I will have to remove the fairings to show you the cable in the other side
Will try to do it tomorrow
Old May 3, 2017 | 09:15 AM
doooooooom's Avatar
Update: So I opened the fairings, and the clutch cable was disconnected from the other end, so I recommended it and everything is working, will just need to adjust the play
Thanks a lot for the help
fbpsb82
Jan 30, 2010 02:23 PM
lsybert
Jun 25, 2009 11:07 AM
red stinger
Jul 19, 2008 12:17 AM
jchookas
Oct 2, 2007 10:49 PM
cyber00677
Jun 23, 2007 06:17 PM
