battery draining when i ride cbr 1000
Old Mar 12, 2012 | 05:19 PM
statechamp152's Avatar
Default battery draining when i ride cbr 1000
i first started up yy cbr 1000 2007 no problem the batt was a lil weak i pull it out of garage cut it off then i go to crank it 5 mins later and battery is weaker so i jump start it then i go ride everytime i cut it off it gets worse acts like it wants to cut off while coming home then i get the battery tested and it say it has 1 volt so i charge it all night and i take it to advance they say the batt is good so i put it back in and the bike starts right up i was thinking battery or the regulator anyone got any ideas thanks
Old Mar 12, 2012 | 05:34 PM
74demon's Avatar
test your charging voltage and check the r/r connector. sounds like the r/r is bad.
Old Mar 12, 2012 | 07:57 PM
MadHattr059's Avatar
Listen to 74, he's been around the block.
Here's the go-to on how-to for your issues...
Charging System Diagnostics - Rectifier/Regulator Upgrade - Triumph Forum: Triumph Rat Motorcycle Forums
Ern
Old Mar 12, 2012 | 10:07 PM
asiddle's Avatar
yeah definitely sounds like your r/r i've had the same problem a time or two its more than likely the problem although as new as your bike is you may want to look into why or what it is that is causing you r/r to go bad(stator,short in wiring harness,etc)
Old Mar 13, 2012 | 08:35 PM
i ordered a r/r idk if thats it i hope its not the stator
Old Mar 13, 2012 | 09:31 PM
Sprock's Avatar
& how old is the Batt ?
Old Mar 14, 2012 | 09:58 AM
had the batt checked its good now im worried if its the stator
Old Mar 14, 2012 | 10:15 AM
74demon's Avatar
if you're worried about it, replace it also. having a new r/r and stator wouldn't hurt.
waynecbr600rr
May 15, 2013 05:46 AM
jays-shop
Feb 27, 2013 12:07 PM
SnakeTheLegend
Apr 4, 2011 06:05 PM
GunMedalGleam
Aug 10, 2009 01:37 PM
njdjh2o
Apr 11, 2008 07:20 PM
