Battery is not charging, battery keep draining.
Old Apr 11, 2008 | 10:38 AM
njdjh2o's Avatar
Default Battery is not charging, battery keep draining.
About 3 weeks ago, the battery drained, brought a new one. Still not keeping a charged, when I ride it, I can see the light flickering the higher I revved the faster the headlight flicker.
I want to say it is the Stator or is it something else I need to check.
Thanks
SGB
Old Apr 11, 2008 | 10:39 AM
njdjh2o's Avatar
Default RE: Battery is not charging, battery keep draining.
Is the F2 and F3 stator swappable?
Old Apr 11, 2008 | 11:22 AM
marc0011's Avatar
My guess is that it is the Regulator/Rectifier (R/R). When they go bad, the battery doesn't charge. Do you have a multi meter? If so, check the voltage that is going into the battery when the bike is reved up to 5000 RPM. It should read 13.5 to 15 Volts. If it isn't post back and we can give you a couple other tests to confirm it's the R/R.
Old Apr 11, 2008 | 12:30 PM
pr0jktmayhem's Avatar
regulator sounds like. because when you mentioned the light flickering.
Old Apr 11, 2008 | 05:44 PM
iRIDE's Avatar
ORIGINAL: marc0011
+1
R/R was my problem. I replaced it and it has run great.
Old Apr 11, 2008 | 07:20 PM
Asmittie84's Avatar
Definetily your R/R. I had the same problem a little bit ago. Fixed it with a 2005 GSXR-750 R/R and it works perfect. Even felt like it gave the bike more pop.
You can find a used GSXR 600/750 regulater on ebay for $30-50 easy.
waynecbr600rr
May 15, 2013 05:46 AM
jays-shop
Feb 27, 2013 12:07 PM
SnakeTheLegend
Apr 4, 2011 06:05 PM
GunMedalGleam
Aug 10, 2009 01:37 PM
teetoe24
Aug 9, 2005 01:46 PM
