Battery Draining?
Old Apr 3, 2011 | 03:18 PM
SnakeTheLegend's Avatar
Default Battery Draining?
2000 Honda CBR600F4 with 2700km on it.
Spark plugs changed
New battery installed (mechanic said it is still juiced)
I think something is draining my battery. Last night I fully charged my battery and installed it into my bike. That same day I took the bike for a drive brought it back in the garage for 15 minutes then took it out again and it died 3 minutes into the ride. I took it back into the garage and recharged it and the same thing happened all over again. Any suggestions as to what the problem might be and what solutions I should consider are appreciated.
Old Apr 3, 2011 | 03:54 PM
RoadiJeff's Avatar
Senior Member & Lord of The Man Cave
If it died while you were riding it's not the battery that is the problem.
Motorcycle Charging System Troubleshooting Guide
Old Apr 3, 2011 | 04:00 PM
Something is draining the battery...I continually have to recharge it...
And if I attempt to turn it back on..there's evident signs that the battery is not supporting the proper voltage required to turnover.
Old Apr 3, 2011 | 04:02 PM
Flyboy's Avatar
I would start with downloading the step-by-step troubleshooting instructions from this link. It will help you narrow down your problem.
electrosport
Old Apr 3, 2011 | 04:07 PM
RoadiJeff's Avatar
electrosport
<tap tap tap> That's the exact same troubleshooting link I already posted 10 minutes ago.
Old Apr 3, 2011 | 04:10 PM
Flyboy's Avatar
Sorry, Im not worlds fastest typer, and it was only 8 minutes ago.
Old Apr 4, 2011 | 10:17 AM
highwaypatrol's Avatar
Have you tried putting a volt meter across the battery teminals whlist the bike is running? It may not be getting a charge from the alternator, which would flatten your battery in no time at all. If you aren't getting a voltage increase with the motor running then I would look at the charging system. A battery that charges on the bench but not on the bike usually points to a fault in the charging system.
Old Apr 4, 2011 | 06:05 PM
cbrzilla10's Avatar
It's the stator or Rectifier/Regulator. Get a multimeter and use that guide!
Then get to riding!
waynecbr600rr
May 15, 2013 05:46 AM
jays-shop
Feb 27, 2013 12:07 PM
GunMedalGleam
Aug 10, 2009 01:37 PM
njdjh2o
Apr 11, 2008 07:20 PM
teetoe24
Aug 9, 2005 01:46 PM
