Battery draining
Old Jul 30, 2009 | 09:41 AM
GunMedalGleam's Avatar
Registered Users
Default Battery draining
Did i search on this forum to get an idea on what my problem was. Common issue was recitiifer so i went out and got a new one. What i find strange is that the standing voltage and the idle voltage is about the same at 12.4. When i rev it up to 5k the voltage goes up to about 3.1-3.2. The old rectifier only gave me 12.7 at the same RPM so there an improvement but still doesn't the voltage sopose to be over 14? Any input of weather my reading are ok before i go out and get stranded again would be appreciated.
Thank you.
Old Jul 30, 2009 | 01:53 PM
Registered Users
Ok here the update. The battery is still draining with the new rectifier. Should i go get a stator now or is there other things that i could check for before hand.
Old Jul 30, 2009 | 08:11 PM
drax13's Avatar
i did the same as you got a rectifier and battery was still draining so i went and got stator tested and sure enough it was bad my advise have it tested before buying one but most likely stator needs to be replaced the usually start goin at 15k mines went to 18k so i really cant complain hope that helps bro
Old Jul 30, 2009 | 09:52 PM
cbtrez's Avatar
Ok here is what the Honda service manual says:
First the batter voltage inspection
With vehicle off
Fully charged: 13.0-13.2V
Under charged: Below 12.3
With High beams on at 5,000Rpm
Measured battery voltage < Measured charging voltage< 15.5V
the above is how it reads in service manual, so if your battery is fully charged it should read no greater then 15.5V while its charging at 5000rmp and it should not read equal to or less then your battery's measured voltage with your engine off.
I had the same problem. My new battery's measured voltage was 12.9V (for the most part fully charged)
I took the reading while bike was on at 5000 RPM it read 14.5V .
So its on my bike its about 1.5V in addition the the measured battery voltage.
I did this with the old battery before i replaced the rectifier and the voltage was the same on or off. So my rectifer was not sending a trickle to my battery.
I noticed that while the bike is running the battery constantly supplies a steady current. The alternator spike charges the battery with 1 or 2 volts additionally all the time. It seems that the battery and charging system are always being used all the time. When the rectifer is dead and or the alternator, the battery runs by itself and it can for about 30 min to 1 hr draining it without replentishment. Its like a give and take deal :P But all take no give =dead battery.
Interesting thing in addtion is i was wondering of getting one of those japanese devices that smooths out power further and helps save fuel by supply constant power for your Fuel computer to prevent hic ups in power delivery. It also takes strain off of the battery from what it says. It acts like a buffer. I do not know much about it . MADE IN JAPAN BELLON FUEL SAVER GAS SAVER (SAVE 10~25%)http://cgi.ebay.com/ebaymotors/MADE-...720161004r7491
Old Jul 31, 2009 | 06:50 AM
98formulaLS1's Avatar
Originally Posted by cbtrez
Interesting thing in addtion is i was wondering of getting one of those japanese devices that smooths out power further and helps save fuel by supply constant power for your Fuel computer to prevent hic ups in power delivery. It also takes strain off of the battery from what it says. It acts like a buffer. I do not know much about it . MADE IN JAPAN BELLON FUEL SAVER GAS SAVER (SAVE 10~25%)http://cgi.ebay.com/ebaymotors/MADE-IN-JAPAN-BELLON-FUEL-SAVER-GAS-SAVER-(SAVE-10~25%25)_W0QQitemZ360172569152QQcmdZViewItemQQims xZ20090720?IMSfp=TL090720161004r7491
This item is complete ****. They won't live up to any of those claims. It's just a large capacitor essentially, which in essence, will kind of absorb any large voltage spikes. It's not very useful, if it were, Honda would have integrated it into your bike.
Old Jul 31, 2009 | 09:13 AM
cbtrez's Avatar
Thanks, sounds good wont be buying this. Battery tender is more useful. Just keep my battery nice when bike is not used.
Old Aug 1, 2009 | 09:26 AM
Registered Users
I Dont think my alternators doing its job, I replaced the rectifier.Bike still aint right. I took a voltmeter and measured the wires on the rectifier. And also all 3 of those yellow wires coming off the stator. All wires read Exactly what the battery measures. Witch is only like 12.6 with the bike on, and thats steadily droping.
Old Aug 5, 2009 | 11:24 AM
cbtrez's Avatar
You may have to swap the alternator, and or recheck the Voltage Regulator rectifier. Im not sure if a alternator can burn out a V.R.R. . But you may want to check if your alternator is shorted across the yellow wires. and check the V.R.R. across where the yellow wires would go while it is disconnected.
So short across alternator =bad I think service manual says anything less then .1 Ohms across the yellow wires = short, im not sure have to confirm this.
Open across yellow wires on VRR while it is disconnected= bad, may be caused by bad alternator.
Good luck with the problem, i hope you find whats wrong.
Old Aug 10, 2009 | 01:37 PM
Registered Users
Question, how much voltage should be coming out of that red wire on the rectifier? Its weird that after i replace the stator those yellow wires started getting plenty of voltage. I measured them to be between 19-24 volts. But the red wire is only showing like 12.4 and dropping.
waynecbr600rr
May 15, 2013 05:46 AM
jays-shop
Feb 27, 2013 12:07 PM
SnakeTheLegend
Apr 4, 2011 06:05 PM
njdjh2o
Apr 11, 2008 07:20 PM
teetoe24
Aug 9, 2005 01:46 PM
