Quick question on Hotbodies Flushmount Install
Old Feb 22, 2009 | 01:19 PM
jmiller427's Avatar
Default Quick question on Hotbodies Flushmount Install
I've searched the how to's - maybe I'm just blind.
Each side has a green ground and then 2 wires - 2 blue and 2 orange. One blue has a white stripe and one orange has a white stripe.
Is the blinker the one with or without the white stripe?
Also - saw the how to about making the running lights work also - does that keep the indicator on the gauge cluster on?
Thanks
Edit - okay, got it. The solid wires are for blinkers, striped are for running lights. But it's going to be a pain in the *** cause now I need resistors.
I want an R6 instead. Anyone want to trade?
Old Feb 23, 2009 | 03:07 AM
Aken's Avatar
July 2008 ROTM
You only need resistors if you want the running light to be dimmer than the turn signal. Personally I like having the brighter light - helps make other people (read: retarded cagers) aware of my presence.
Remember to use diodes, too, so your turn signal indicators on the gauge act normal
Checkered Past
Apr 15, 2012 05:04 PM
GPCBR6
Jun 29, 2009 12:42 PM
VTcbr
May 22, 2009 07:26 PM
VTcbr
Mar 23, 2009 02:34 PM
snowboarding82
Apr 5, 2007 10:54 AM
