Hotbodies flushmount blinkers install......
Old 05-22-2009, 06:42 PM
Default Hotbodies flushmount blinkers install......
Alright so the choice of flushmounts that i'm going with is going to be a nice clear hotbodies.
Who here can vouch for the pain in the a$$ level pertaining to install?
Do the fairing need to be taken off and whats the deal with possibly having to use diodes to compensate for the 2/3 ratio wiring?
thanks
Old 05-22-2009, 06:54 PM
ibiggers's Avatar
I just did mine on Wednesday night. It is soo easy. Just take the three hex bolts out of the fairing right near the blinker and pull out on the front fairing and that should give you enough room to get a racheting box wrench to get the stock blinker off. I used 3 of the shims that come with it and it went really smothly... Good Luck...only tip that I almost didnt catch is make sure the fairings line up with the black v piece before you go out riding and make sure that all the wires are tucked away... It took maybe 20 minutes, but that was because I used the headlights from my civic as the light to install them.
Old 05-22-2009, 07:20 PM
I've heard you need to compensate the 2-3 ratio wiring....could you elaborate more on the wiring process?
Old 05-22-2009, 07:23 PM
redzintimidator's Avatar
If you want blinkers AND running lights you need to do that. I wrote up a how to in the "how to" section of the forum to do that. If you just want signals, but no running lights then dont worry about diodes.
Old 05-22-2009, 07:26 PM
oh btw...the wires for the signal only are the black one and the solid color. NO WHITE STRIPE
GPCBR6
06-29-2009 12:42 PM
VTcbr
03-23-2009 02:34 PM
jmiller427
02-23-2009 03:07 AM
snowboarding82
04-05-2007 10:54 AM
exitnas
08-16-2006 03:14 PM
Quick Reply: Hotbodies flushmount blinkers install......
Contact Us - Archive - Advertising - Cookie Policy - Privacy Statement - Terms of Service
© 2019 MH Sub I, LLC dba Internet Brands
We are a participant in the Amazon Services LLC Associates Program, an affiliate advertising program designed to provide a means for us to earn fees by linking to Amazon.com and affiliated sites.
