Please help testing Fuel Pump 2005 F4i
F4i. I found the issues. My ground for 3P connector to Fuel Pump is no good. It works intermittently. Hence sometimes i got power when first reading it and sometimes i got nothing. Second issue is my fuel pump only work sometimes too. When connect directly to the battery the pump work and then stop and then stop. I tried it again after 5 minutes and it work.
Anyways, thank you for helping me with F4i issues. I guess i am done with that bike. I am going to order a new pump soon.
Moving on to 600RR, i think i will be okay with it. It doesnt do anything really with MAP being faulty and knock sensor not working. I want to reset it but i do not have the tool listed to jump the DTC. Unless you know other way to reset it. Thank You
wow that was cold. but thanks for letting me know. I tried and it cleared. However it just came back again. Same cold 2 and 25. The light doesnt bother me. What i need to know is your advice on not fixing it. the service manual says "Engine operate normally" doesnt that me it will not affect my engine now or in the future either?
code 2 and code 25 are both for 600rr. I thought code 25 is knock sensor? I think I can jump the knock sensor to get rid of code 25. Code 2 I need to get take the fairings off to access the gas tank. It will suck. Thank you though
thank you. i was on a cruise for a while. i didnt have time to check. i will check it later. but i am sure i can just replace it easily and cheaply like you said. thank you agian
