testing fuel pump ( need confirmation)
Old May 17, 2007 | 08:38 PM
byc_panty's Avatar
Default testing fuel pump ( need confirmation)
this is how i did it..i just want confirmation plz..
i pulled out the fuel outlet line from the fuel pump and directed it to a bucket...
when i turned the key to "on" no gas was comming out...
and my dad told me to start the engine.... and i did with the start button... than we saw gas comming out of the line...
does this confirm the fuel pump and fuel filter is good?
sorry im a big newb
Old May 17, 2007 | 10:57 PM
dementedf3's Avatar
Default RE: testing fuel pump ( need confirmation)
fuel pump ony pumps while cranking and running, so i would say yes your pump is working. Can't say the filter is good but it is good enough to let gas through. What is the problem you are having??
Old May 18, 2007 | 01:58 PM
byc_panty's Avatar
my bike has difficulty starting up sometimes... and requires me to play with the idle ****... and give it some gas...
before my bike would stall wehn im stopped at a red light...(with plenty gas inside)./.. i cleaned outt he air filter cause it was filthy...and thought it solved the issue..but just yesterday it was having some mild difficulty starting up again...
i m gona buy a new fuel filter and see if it makes a difference...
im not sure in how to take apart the petcock to inspect that part tho...
Sean1000f
Oct 19, 2017 01:16 PM
dj600f4i
Mar 6, 2012 02:55 PM
Cr250r67
Sep 3, 2011 11:41 AM
zblad
Dec 5, 2008 01:14 AM
