oil filter removal
Old Mar 1, 2006 | 03:10 PM
  #21
Litre1's Avatar
Default RE: oil filter removal
I decided on the Leo Vince ultra high pipe system. It should be here in about a week, so I'll post up how much workspace I have with the oil filter.
Old Mar 27, 2006 | 07:35 PM
  #22
RugbyCanada's Avatar
ORIGINAL: kiggy74
Get a filter socket. They come is a variety of sizes, you can get one anywhere, walmart, meier, etc. If you have an extension for your ratchet you won't even need to take the fairings off.
hi kiggy/ and others. New to the site, and i'm sorry for resurrecting an old thread. I'm having trouble getting the filter off, and was trying to avoid removing the lower cowl/right side fairing. are you saying that there is a trick to remove the oilfilter with out farting with the plastic?? Any advice would be GREATLY appreciated.
note--every manual I've read says to take the plastic off.
thanks in advance.
Old Mar 27, 2006 | 11:40 PM
  #23
delta's Avatar
try something like this : http://www.partsamerica.com/ProductD...tnumber=10601B
Old Mar 28, 2006 | 12:38 PM
  #24
Tahoe SC's Avatar
yo mang...i don't take off mah plastics...i go through the front, where the V-fairing is.
but for the first change, the filter was put on by the terminator himself (not arnold but the real terminator) so it was way tight so i busted the bitach all up and got the filter off and then i said 'hasta la vista stock filter' and no problems.
does get a bit messy but if you put rags, etc. under the filter all good mang!
Old Mar 28, 2006 | 12:58 PM
  #25
RocketDude's Avatar
I tried a screwdriver plus every remover Wally World had at 1130pm! I finally got it with a standard oil filter wrench with a kitchen rubber glove over the filter for traction. The gloves are trashed but after two trips to wally world, I was ready for anything. Use a pop-stick to scrape off the burnt gasket. No metal to metal. They must put them on dry. Good luck
adapt63
Nov 6, 2013 05:06 PM
Hudson
Apr 1, 2012 01:13 PM
raj1976
Jun 11, 2009 10:43 PM
tyson_rr
Dec 15, 2007 05:44 PM
Angryviking
May 26, 2006 11:49 PM
