oil filter removal
RE: oil filter removal
Thanks for the help.
As you can probably tell I/m a rookie. Just bought a 2005 Cbr600 F4i and have allready drop it in the garage!
trying to back it out . Not too much damage, but I did break the right hand mirror off and a eyelash looking scratch over the headlight.
At least now I won't have to worry about that 1st scratch.
Only a week old.....
Thanks again,
Lumberman
Thanks again,
Lumberman
ORIGINAL: sirlimpzalot
or if you want...
just take a long screwdriver and ram it thru the oil filter and use it as a "handle" since you are throwing it away anyway...if you use a K&N oil filter they have a nut on the end which makes it way easier to remove next time
or if you want...
I've had to use the old screwdriver technique many a time. My ex-girlfriend had a nissan sentra. God damn filter was in such an awful place a screwdriver was all that would do it. If you don't jam it in right near the base there's no problems. This is usually a last case scenario kinda thing... but it doesnt hurt anything.
ORIGINAL: xmunxjai648
don't use a screw driver and ram it into the oil filter...u can accidentally damage ur thread
It is a good idea to get some carb/contact cleaner and spray off the headers and anywhere the oil might have dripped or splashed. That way you minimize the smoking effect when you restart the motor
