Fuel pump not priming after crash
Old Aug 6, 2011 | 11:19 PM
jveach's Avatar
Default Fuel pump not priming after crash
Ok so I'm sure some of you seen where I crashed the other night, If not then here is the thread
https://cbrforum.com/forum/off-topic...t-down-129214/
well here is my question, after the wreck I found the main fuse to blew, so I replaced it and got the gauges to light up and all that good stuff, but I don't have the FI light come on and the fuel pump doesn't prime, any quick suggestions where too look next?
Old Aug 6, 2011 | 11:21 PM
Kuroshio's Avatar
BAS. Having seen the pics you might wanna check if it's still in there somewhere. If it is, bypass it cause there's no way in hell it thinks the bike is upright.
Old Aug 6, 2011 | 11:22 PM
jveach's Avatar
what is it normally attached too? is it one of the two relay thingy's that one the headlight bracket? I'm new to the F4i so I'm a bit lost on it
Old Aug 6, 2011 | 11:33 PM
Kuroshio's Avatar
search "bank angle sensor". I only know what it does. I've never had cause to go looking for it. I know it's somewhere in the headlight region
Old Aug 6, 2011 | 11:48 PM
jveach's Avatar
thanks for your help, I found it, but the service book says to check voltage on three wire (white/black to green) and (red/black to green) as fate has it my multimeter was under the seat when I crashed and is gone. Anyone know how to bypass this as I have no clue
Old Aug 7, 2011 | 10:56 AM
Dragondima's Avatar
You cross the red and green together.
Old Aug 7, 2011 | 03:18 PM
jveach's Avatar
thank you, this worked perfect. bike fired right up
whatthekrapp
Jun 17, 2013 11:12 PM
my750
Mar 15, 2012 09:14 PM
02mattf4i
Jan 31, 2012 08:23 AM
adam833
Jun 24, 2011 08:40 PM
Adrjunkie
Jun 22, 2009 07:38 PM
