Fuel pump not priming after crash
Ok so I'm sure some of you seen where I crashed the other night, If not then here is the thread
https://cbrforum.com/forum/off-topic...t-down-129214/ well here is my question, after the wreck I found the main fuse to blew, so I replaced it and got the gauges to light up and all that good stuff, but I don't have the FI light come on and the fuel pump doesn't prime, any quick suggestions where too look next? |
BAS. Having seen the pics you might wanna check if it's still in there somewhere. If it is, bypass it cause there's no way in hell it thinks the bike is upright.
what is it normally attached too? is it one of the two relay thingy's that one the headlight bracket? I'm new to the F4i so I'm a bit lost on it
search "bank angle sensor". I only know what it does. I've never had cause to go looking for it. I know it's somewhere in the headlight region
thanks for your help, I found it, but the service book says to check voltage on three wire (white/black to green) and (red/black to green) as fate has it my multimeter was under the seat when I crashed and is gone. Anyone know how to bypass this as I have no clue
You cross the red and green together.
thank you, this worked perfect. bike fired right up
