Bike won't start
Old Apr 11, 2018 | 12:43 AM
Kevin Quan's Avatar
Exclamation Bike won't start
Hello all,
I'm new to this page and am seeking help before I part ways with my 04 Honda CBR 600 f4i. Any help is appreciated.
Problem: Bike will not start
- no fuel prime
- no power to headlight (low or high)
- bike turns over when I jump the starter relay (bike doesn't do anything when I press the push start button)
- rear lights don't work
- spark plugs are good, I get great compression when I jump the bike to turn over
- power is going into kill switch and push start button
- battery is good
- fuses are all getting power and I checked for continuity. All is good in the fuse box
- I switched the headlight relay and fuel pump relay but nothing happened
Bike is in Neutral when I turn the key. Kickstand Sensor is not the problem, nor is the BAS or the big main light harness that people say can get loose sometimes.
Old Apr 11, 2018 | 01:53 AM
CaBaRet's Avatar
Hi ,did you check the 30amp fuse at the starter solenoid
Old Apr 11, 2018 | 08:25 AM
trachito's Avatar
Do your gauges light up? if not, it sounds like the 30amp fuse Cabarat mentioned
Old Apr 11, 2018 | 02:19 PM
Kevin Quan's Avatar
Default Thanks for replying. This bike is stressing me out so much.
30amp fuse is good. The photo attached shows what lights pop up when I turn the key.
Note: nothing happens when I press the push start button. Bike only turns over when I run a wire from the battery into the starter solenoid.
Old Apr 11, 2018 | 03:43 PM
CaBaRet's Avatar
Do you mean your bridging the starter solenoid to start the engine
Old Apr 11, 2018 | 04:18 PM
Kevin Quan's Avatar
yes
Old Apr 12, 2018 | 02:14 AM
CaBaRet's Avatar
Then you will need to buy a new Starter Relay Switch (Solenoid)
Old Apr 14, 2018 | 05:30 PM
E.419's Avatar
So the pump is not priming when you turn key on?
Old Apr 18, 2018 | 02:04 PM
trachito's Avatar
you said the power is good going into the kill switch/start. maybe it's not making contact when you push the button and power isn't going to the start switch to the starter.
CBR-J
Aug 16, 2017 09:19 PM
Freewax
F2 Tech
Mar 5, 2011 09:37 PM
pskillman
May 1, 2010 06:45 PM
Slim@SBF
Dec 9, 2007 08:53 AM
cbr714
Jun 10, 2007 07:55 AM
