Bike won't start
Hello all,
I'm new to this page and am seeking help before I part ways with my 04 Honda CBR 600 f4i. Any help is appreciated. Problem: Bike will not start - no fuel prime - no power to headlight (low or high) - bike turns over when I jump the starter relay (bike doesn't do anything when I press the push start button) - rear lights don't work - spark plugs are good, I get great compression when I jump the bike to turn over - power is going into kill switch and push start button - battery is good - fuses are all getting power and I checked for continuity. All is good in the fuse box - I switched the headlight relay and fuel pump relay but nothing happened Bike is in Neutral when I turn the key. Kickstand Sensor is not the problem, nor is the BAS or the big main light harness that people say can get loose sometimes. |
Hi ,did you check the 30amp fuse at the starter solenoid
Do your gauges light up? if not, it sounds like the 30amp fuse Cabarat mentioned
Thanks for replying. This bike is stressing me out so much.
1 Attachment(s)
30amp fuse is good. The photo attached shows what lights pop up when I turn the key.
Note: nothing happens when I press the push start button. Bike only turns over when I run a wire from the battery into the starter solenoid. |
Do you mean your bridging the starter solenoid to start the engine
yes
Then you will need to buy a new Starter Relay Switch (Solenoid)
So the pump is not priming when you turn key on? |
you said the power is good going into the kill switch/start. maybe it's not making contact when you push the button and power isn't going to the start switch to the starter.
