Bike won't start
Hello all,
I'm new to this page and am seeking help before I part ways with my 04 Honda CBR 600 f4i. Any help is appreciated.
Problem: Bike will not start
- no fuel prime
- no power to headlight (low or high)
- bike turns over when I jump the starter relay (bike doesn't do anything when I press the push start button)
- rear lights don't work
- spark plugs are good, I get great compression when I jump the bike to turn over
- power is going into kill switch and push start button
- battery is good
- fuses are all getting power and I checked for continuity. All is good in the fuse box
- I switched the headlight relay and fuel pump relay but nothing happened
Bike is in Neutral when I turn the key. Kickstand Sensor is not the problem, nor is the BAS or the big main light harness that people say can get loose sometimes.
- no fuel prime
- battery is good
30amp fuse is good. The photo attached shows what lights pop up when I turn the key.
Note: nothing happens when I press the push start button. Bike only turns over when I run a wire from the battery into the starter solenoid.
Freewax
F2 Tech
Mar 5, 2011 09:37 PM
Slim@SBF
Dec 9, 2007 08:53 AM
